Results 1 to 10 of 15
- May 2005
- 66
January 8th, 2007 01:48 PM #1hi guys, have you tried using cyclo cooling system 'stop leak & sealer'? saw this product in concorde megamall, costs P179.75. my car has a leak on the radiator plastic top and hoping this could solve temporarily without any adverse effects.
TIA
Zombie
- Aug 2006
- 728
January 8th, 2007 05:44 PM #2hmm... we haven't tried using those. mejo mura kase sha, for what the claims it can do. baka pag maliit lang butas lang.
January 8th, 2007 06:00 PM #3
ginamit ng pinsan ko iyan sa aircon bus nila .Ok naman nakaluwas ng maynila
pang remedyo lang talaga iyan .better ayusin talaga ang problema
hindi remedyuhan lang
July 16th, 2007 08:12 PM #4
i just bought this one a while ago. drained my power steering reservoir using a used aquarium hose and a syringe. Dunno proper way of draining and might be messy and takes lot of work and time. nawala na yun ugong on mg 94 gli bigbody corolla, change also may power steering hose na din before pero after 2 mos may konting sirit na fluid then yun ugong kapag nakatodo liko. will post results after
July 17th, 2007 09:17 AM #5
Gamit ko Water Stop. 50 petot lang sa suking tindahan. May maliit na crack na kasi sa plastic top ng rad ko. After 2 months ok pa naman sya. Di pa naman ako nababawasan ng tubig. Effective and cheap
July 17th, 2007 09:45 AM #6
Used a similar product from Prestone, although mas mahal (P279 ata price). IMHO, ineffective siya, kasi medyo malaki yata butas ng radiator ko. All it succeeded in doing was clogging the hose to the reservoir tank. Sayang lang pera ko. Pang maliliit na butas lang sya pwede siguro.
May bagong produkto ang Cord Chemicals, Gladiator Sealant, pang-radiator talaga. Saw one at Ace hardware SM Cubao, but didn't check the price.
July 17th, 2007 10:04 AM #7
ung gladiator na yon mga around 300, 2 sets ng a&b, mayroon sa hardware namin, tinago ko yung isa (for emergency) mahal lang, kaya yung stock sa hardware di padin napapalitan... kung may butas na, pagawa mo nalang, kasi mga yun temporary solution para kung on the road ka nasiraan, madadala mo pa sa shop/uwi ang sasakyan....
July 17th, 2007 10:36 AM #8
hindi recommended mga sealer for long term, ok lang yan for temporary fix like if la ka time to have the repairs done.
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 19th, 2007 08:44 AM #9gladiator is good pero use it as a patch lang... not the solution to the problem.
July 19th, 2007 12:55 PM #10
tama--sealers are not pansaman-tagal...immediate remedy lang at pang pinholes lang mga yun...
