Results 11 to 14 of 14
- Aug 2005
- 553
September 26th, 2014 12:20 PM #11
- Aug 2005
- 553
September 26th, 2014 12:24 PM #12The radiator in theory can only cool until ambient temperature. But in cars, the optimal temperature range is anything from 85C-96C depending on the design and set fuel ratio.
So effectively when calculating for engines, radiators are designed to have something like a temperature delta of 50C from ambient. Meaning, if ambient is 35C, the radiator must keep the engine at about 85-90C.
So to add on to answering your question, if your engine runs any cooler, there will be a significant drop in efficiency due to lowered combustion rates. And even then your AC will not be any cooler than ambient nor will it be able to remove humidity.
- Oct 2014
- 2
October 26th, 2014 05:59 PM #13Mga Bossing sa Tsikot.com. Bago lang po ako dito. Meron po sana ako katanunga. Hindi ko po nabasa ang lahat ng Thread. So baka meron na pong kasagutan sa tanong ko. Meron po ako 2006 Nissan Urvan escapade. Ok naman po ang lahat except sa Overheating issue nya. Pag po running yung van ok naman po ang temp even naka on ang A/C. Pero po pag na traffic thats the time mag increase yung temp up to the point na papataying mo na ang a/c para hindi na tumaas. Kala ko Radiator proble kaya pinaoverhaul ko na pero the problem still pag traffic. Ano po kaya problema at magandang solution? I hope makatulungan nyo ako. Maraming ty po.
October 26th, 2014 06:59 PM #14
^check your rad fan. Baka faulty fan motor na yan, or faulty thermoswitch.
Question nalang is what are these toyota units that uses e-CVT? I only know of Rav4 based on their...
Toyota Hybrid E-CVT transmission fluid
