Quote Originally Posted by audio_hunter View Post
Well sir, not to offend your BS Engineering Degree (for whatever it is) ....hmmm tsk tsk tsk
I dont have to flaunt my qualifications/company... here's my PRC Mechanical Engineering License 0048147-98. You can verify it at PRC & I'll send you my name thru PM to confirm.
Though what you've said about the moisture were correct (since you may have read it also from the internet (google maybe)) I agree with you.
Thanks. But I dont need Google to explain this.
...shaft seal leak is the worst simply because, ...Pinhole at the shaft seal cannot hold even 100 psi pressure.
[SIZE=4]It can be smaller than a pinhole or a misalinged seal or loose nut?[/SIZE]
May I ask you a question sir, do you know what will happen to the "freon" if it will leak somewhere in the cooling system ? will that part be cold as if the "freon" is leaking thru it? i'll tell you sir, it will not. what you can see is just a stain of leaked freon.
[SIZE=4]YES it will be cold & there will be frosting at worst if the leak is too much! As to the stain. There's no stain, because its gas. How can it stain metal or rubber? Kaya nga technician use bubbles to detect a leak. Maybe the stain you are talking about is caused by the compressor oil if it gets out with the freon on certain cases.
Ganito, next time you have your car A/C cleaned, yung freon na pasisingawin thrust it to a metal surface, then touch it. Tell me kung malimig.
[/SIZE]
"....heat is not rejected through a/c condenser in front of your car and radiator but it merely lowers down the pressure as for the temperature of liquefied refrigerant
[SIZE=4]Are you 100% sure that the condenser infront of the car is just to "MERELY" lower the pressure/temperature & heat is not rejected? Are you willing to bet your car on that? I am!
Check the link pheztie posted.
ps: den1106 (above) wants to know your source on the condenser
I need not explain more.
The 2 guys above pheztie & den1106 are boggled by your explanation.
[/SIZE]"then expanded again for evaporation (at the cooling coils/eveaporator). "--- correction sir it is not "expanded again for evaporation" it is expanded as it passes through TXV or an orifice that regulates the refrigerant flow into the evaporator.
[SIZE=4]Pheztie above is kind enough to send us a (link)diagram. Look what comes after the condenser. Its the expansion valve. The orifice you are talking about is called expansion valve & leads to the evaporator.
[/SIZE]
We're both members of this forum/group since I believed, we both want to help others (not to mislead them) and we're both eager to explore and learn new things that we merely knew.
[SIZE=4]I dont mislead them. I comment when i know my stuff, modesty aside.
[/SIZE]
Cheers also to you sir..
[SIZE=4]Cheers & peace![/SIZE]
