Results 1 to 15 of 15
    Apr 2009
    Hi fellow tsikoters....
    Just want to know your experiences and views on using coolant or just plain water on the radiator...
    dati kasi water lang sinasaksak lang hose sa radiator then dumating na itong mga coolant.
    Sa akin kasi i use distilled water, d ko lang alam baka pareho lang pala sa tap water, kasi in time nagkaroon din kalawang.
    thanks
    Jun 2007
    I personally use a 50-50 coolant-distilled water split. coolants supposedly help retard some of the corrosion.
    But as long as it isn't tap water, your radiator should be fine
    For me i'm using the red Toyota coolant 50-50 with distilled water. I think the higher boiling point and anti-corrosive characteristics are reasons for using coolant. Consistent ang kulay niya not compared sa tubig, nagkukulay kalawang.
    +2 cents
    Quote Originally Posted by anthon05 View Post
    thanks
    Coolant raises the Boiling Point and the Specific Heat of your radiator water. Best in combi with distilled water.
    Aug 2004
    Using distilled versus tap water saves you from scale build-up, but it won't prevent rust.
    Using a coolant mix benefits you in that coolant prevents rust formation and coolant raises the boiling point of your cooling system. Some people yabber on about water having higher heat capacity... but heat capacity doesn't do nuthin' for you if your water is boiling over... as the heat capacity drops drastically as you lose water. Coolant prevents or delays boil-over, and allows your system to take a little more heat abuse.
    Feb 2009
    thanks
    anthon05,
    the antifreeze/coolant in your cooling system does more than just cool the engine llike water. it prevents corrosion: water in the cooling system of bimetallic or more different metals engines causes electrolysis. the aluminum/cast iron engines, of course bimetallic, has different electron number for different atoms, hence the electrical charge exists between two dissimilar metals. the metal with higher electron number donates electrons to the lower electron numbered metal- cause of corrosion.
    the antifreeze/coolant also conducts more heat faster to carry to the radiator to reduce the fever of the engine block. it also is the only lubrication for the moving parts in the cooling system. it rasises the boiling point like sugar when added to water raises the boiling point of the solution. it lowers the freezing point of the coolant solution like vodka added to water, lowers the freezing point. your fridge can be used for this experiment. try freezing vodka, vodka/ water and just plain water. then enjoy the liquid vodka with orange juice since your fridge is incapable of freezing the vodka.
    jick
    instructor
    guam community college
    should be a mixed solution for pure coolants.
    but as far as i know, prestone coolants are already premixed, so you can pour it directly.
    AFAIK, coolant/anti-freeze prevents water from freezing like in other countries where outside temperature reaches zero degree Celsius. Therefore, if it used here in the Phils, it only adds heat to a car's engine. Try to soak your hand in a pure coolant, then, you would know which makes your car's engine cooler.
    coolant for me....I just buy from Honda yun pre mixed coolant nila.
    marami kasing na hassle pa bumili ng coolant since kailagan pang haluan ng water, but marami ng mga coolant na pre-mixed so diretso na ilalagay...
    Jan 2009
    Always consult your car's owner's manual for specific instructions on what type of coolant to use and at what concentration. Some engines require coolants with little or no silicate content. Using the wrong coolant could shorten the life of the water pump.
    Quote Originally Posted by orlee_v View Post
    And your point being?
    Or are you implying that using coolant additive is bad?
    Sep 2004
    Quote Originally Posted by 1D4LV View Post
    Prestone still sells Coolant Concentrate, although mas prominent sa shelves yung pre-mixed (cheaper too, since its pre-mixed already).
    i use the concentrated one (prestone) mixed 50-50 with absolute distilled water. but most important is walang leak somewhere or radiator cap for maximum protection.
    Guys,
    Gumagamit din ako ng Prestone Coolant and i'm using 50/50 water mixture. I agree to the earlier threads about the benefits of using a coolant.
    -I would like to add:
    *Boiling point will depend on the cooling system working pressure (you can see the rating on your radiator cap).
    *Using coolant a derating effect will occur on the system. (but that dearting effect is already taken cared off during the design stage of the radiator). Coolant mas mababa ang specific heat at mataas namn yung density, comapred to water.
    *If you happen to be in the radiator workshop, makikita nio yung difference if you're using a coolant.
    Mas maganda talaga with coolant ang system, 16 years na po ako bilang designer ng mga radiator sa pinas at middle east.
    Feb 2009
    thanks
    anthon05,
    just to add to the discussion, there are two kinds of antifreeze/coolant available nowadays. there are ethylen glycol (usually greenish, toyota original coolant is brownish) and propylene glycol, this one is orange tint. the ethylene glycol have a service life of two years before you drain and refill to guarantee the protection level. the propylene glycol coolant is used on some cars produced since 1995. these two are never to be mixed or the protection levels will be compromised. the service life for propylene glycol is abut five years. environmental concerns prompted the design and production of this newer coolant that you do not need to dump toxic coolant into the water ecosystem. please be earth friendly. we only have one of it and there is no substitute.
    jick
    instructor
    Apr 2009
    Thanks to all.. appreciate the advice and infos
    another thing how many liters should i buy? if coolant is 50% ... ilan liters total capacity ng radiator for my crosswind xto?
Anong mas maganda coolant or plain water sa RADIATOR?
