Results 11 to 15 of 15
May 28th, 2009 11:53 AM #11
May 28th, 2009 12:19 PM #12
i use the concentrated one (prestone) mixed 50-50 with absolute distilled water. but most important is walang leak somewhere or radiator cap for maximum protection.
- Feb 2008
- 46
May 28th, 2009 12:20 PM #13Guys,
Gumagamit din ako ng Prestone Coolant and i'm using 50/50 water mixture. I agree to the earlier threads about the benefits of using a coolant.
-I would like to add:
*Boiling point will depend on the cooling system working pressure (you can see the rating on your radiator cap).
*Using coolant a derating effect will occur on the system. (but that dearting effect is already taken cared off during the design stage of the radiator). Coolant mas mababa ang specific heat at mataas namn yung density, comapred to water.
*If you happen to be in the radiator workshop, makikita nio yung difference if you're using a coolant.
Mas maganda talaga with coolant ang system, 16 years na po ako bilang designer ng mga radiator sa pinas at middle east.
May 28th, 2009 05:48 PM #14
anthon05,
just to add to the discussion, there are two kinds of antifreeze/coolant available nowadays. there are ethylen glycol (usually greenish, toyota original coolant is brownish) and propylene glycol, this one is orange tint. the ethylene glycol have a service life of two years before you drain and refill to guarantee the protection level. the propylene glycol coolant is used on some cars produced since 1995. these two are never to be mixed or the protection levels will be compromised. the service life for propylene glycol is abut five years. environmental concerns prompted the design and production of this newer coolant that you do not need to dump toxic coolant into the water ecosystem. please be earth friendly. we only have one of it and there is no substitute.
jick
instructor
guam community college
- Apr 2009
- 536
May 28th, 2009 06:49 PM #15Thanks to all.. appreciate the advice and infos
another thing how many liters should i buy? if coolant is 50% ... ilan liters total capacity ng radiator for my crosswind xto?
