Results 1 to 10 of 22
- Aug 2012
- 8
August 27th, 2012 08:41 PM #1Hello po... just want to ask if need pa po ba idala sa talyer ang sasakyan pagmagddrain ng radiator o pwede kahit ako lang po.. and if ever pwede kahit ako lang, can i ask for guidelines and procedures, also what type of coolant should be used.
Toyota Hilux Surf 91 model po yung gamit ko...
Maraming salamat po.
- Aug 2005
- 553
August 27th, 2012 09:20 PM #2You can do that on your own.
Make sure the engine has been off for a few hours so as to avoid dealing with 2nd degree burns.
1. Get a 3-4 liter container and put it under your radiator drain.
2. Unscrew (its a plastic wingnut) the plug which is normally situated on the lower tank of the radiator.
3. Drain.
4. Tighten the plug.
Make sure you dispose of the liquid in a proper sewer drain not on the ground.
Now before you fill up your system again.
1. Get a radiator flush and fill it in
2. Add water.
3. Run your engine, intermittently revving to circulate and turbulate the detergent. Idling for about 15-30 minutes as necessary depending on the residue from the initial flush.
4. Drain the engine as per the procedure above.
Rinse and repeat as necessary so you can get as much corrosion out as possible.
Personally I would put a mesh during flushing on the radiator inlet to catch any loose debris.
Fill up your cooling loop with 30% coolant and the rest with clean preferably filtered water.
I recommend blowing air through your radiator core to dislodge dust and debris.
Wouldn't hurt to shampoo to degrease it and rinse with low pressure hose your thumb on the hose should work fine. Dry with pressurized air or just let it dry on its own.
- Aug 2012
- 8
- Aug 2005
- 553
August 28th, 2012 05:38 PM #4You're welcome.
Likewise, its important to note that given the age of our engine it may not just be the radiator you need to flush clean but your engine as well, especially if its been running with no coolant for a long time.
Be weary of those "radiator overhaul" places most of them don't understand the science of radiator construction.
Mura nga pero masmahal ang magpa-overhaul ng makina.
- Jul 2017
- 7
July 22nd, 2017 06:14 AM #5I'm just a newbie, unable to post new thread sorry for hi jacking this thread my apology ..
Naka bili ako ng second hand Honda idsi 2004 a 13yr old car w/ 81k kl. reading odometer
previous owner used water on its cooling system never mention if its distilled or tap water( ayaw na kasing mag reply inquiry ko. I do have plans of draining it or perform flashing(flashing solution) procedures, but I'm a bit worried about all the dirt residue will come out that will have a possibility to trap on its way out.
Please advice me what to do...
1. just drain the old cooling liquid then replaced w/ distilled water
2. perform flashing procedure (flashing solution) then replaced with distilled water + coolant solution 50/50.
please help me decide
July 22nd, 2017 06:41 AM #6
First, its toilet "flush". hindi "flash"light.
There are lots of videos how to flush your radiator.
Once you drain the old coolant, you'll see naman if there are debris. Normally minimal if the car isn't too old.
Why are you scared to flush? Its just like mumog? the more the better...
Always use coolant mix not just water.
- Jul 2017
- 5
July 24th, 2017 03:35 AM #7
July 24th, 2017 10:30 AM #8
- Jul 2017
- 14
July 27th, 2017 08:11 PM #9Good pm po, newbie lang po pasensya na at makiki ask na rin dito sa thread nag hahanap hanap lng po same case sa Toyota bb ko. Yung red light sa dash board ko po temperature nag biblink po pinatakbo ko lang 80 steady sa nlex mejo mainit po panahon non tsaka naka on ac ko. 10-15 min pa lang nag blink na. Ngaun lng po nangyari sa BB ko po yun. Dibala ko na po sa talyer, suspected nila na sa radiator ang tama. Na need ko ipaoverhaul. Ok naman po yung fan gumagana. Now lang nagkaroon ng overheating problem tong si BB. Ipapa overhaul ko na po sya nakabili na rin po ako nng 5050 coolant mixture sa toyota. Tingin nyo po? Alam ko po gasgas na tong tanong ko haha gusto ko lang po makadinig ng opinion from other car users. Salamat po.
Edit:
Pag umaga naman po, check ko yung radiator kumpleto naman po yung leve ng tubig. Meron din po yung parang storage sa right side nakalagay sa cap "coolant" may level na full and low. pero wala po yun laman. Sabi po ng mekaniko ok lang naman daw po un kahit wala un laman. Ano po b yon? Overflow tank po ng coolant? Konti lng po alam ko sa kotse haha pasensya na po trying to learn lang po
July 27th, 2017 08:38 PM #10
hanap ka na ng ibang mekaniko sir. hindi pwedeng ok lang kung walang laman ang reservoir.
marami pang dapat i-check dyan sa cooling system mo;
gumagana nga ang fan, sufficient pa ba ang airflow?
thermostat, ok pa ba? or baka wala na.
water pump, ok pa ba? baka OEM pa ang nakakabit dyan.
and the list goes on,,,,
VinFast VF 3
