Results 1 to 14 of 14
    Nov 2007
    Hi Guys, Im quite new here yet I have tons of problems regardinig my ride.
    First problem is my aircon compressor. I just want to know if the aircon compressor of SR20 engine compatible with the aircon compressor of nissan cefiro 97 model? I replaced the compressor of my nissan cefiro with the above mentioned compressor(with a little alteration on the high and low pressure tubes) and im not quite sure if the engine can take the load of the new compressor or if it will interfere with the computerbox. I also here (makinilya) noises as I speed up or accelerate does the compressor has anything to do with the tyope sound of my engine?
    Pls advise thanks.
    Quote Originally Posted by wayne28 View Post
    Pls advise thanks.
    Not sure about your compressor but the engine sound might be a problem with your gasoline quality or air-fuel ratio. Are there any modifications done to the engine aside from the compressor?
    Nov 2007
    Havent tried using a high octane rating gasoline since I bought the car 3weeks ago. How about the fuel air mixture? how to check on that?
    You'll need to find a tuner shop who has an air-fuel meter. Speedlab has one.
    Another possibility is your ignition timing is not correctly set (maybe too much advanced).
    Doesn't the Cefiro require 95 Octane? I remember that quite a few Nissans from that time did.
    Yes the Cefiro requires 95, if you want to make sure teh AF is right, just bring it to your nearest casa for a tune-up and it's included with the service (they'll be using the CONSULT II tool).
    As for the compressor, not really sure as the Cefiro uses a computer-based AC system, right?
    Nov 2007
    I will be goin to speedlab tomorrow for tune up and check-up. I will update you guys after tomorrow
    Check the following:
    - timing (although it should be set already as the timing of the Cefiro is done through the computer)
    - fuel; The cefiro requires 95 octane. Petron XCS is okay.
    - knock sensor
    Nov 2007
    Knock sensor? where will i find the knock sensor? Thanks
    Nov 2003
    the sound from the engine is knock. you have to use blaze or velocity on the cefiro.
    Nov 2007
    Went to Speedlab last Saturday. The chief mechanic also gave me the same advise. He said that I should use a higher octane gasoline and also try to use octane booster for my car. fixing the air fuel ratio of my car will require me to buy a computer box that will cost 30k. The mechanic, however, told me that its a common problem among cefiros of the same model and also told me that it will not affect or damage my engine. I hope its true!
    Nov 2007
    Im now using petron blaze and finally nawala na engine knock ng cefiro. Thanks to the guys na nag advise. I am now going to tune my car up and buy new sparkplugs. Any idea on which plugs to use and where to buy it?
    Maybe a set of BOSCH platinum tip sparkplugs so you don't have to replace them for a longer time than with ordinary sparkplugs. I think you can buy these at ACE hardware or True Value stores.
    Jan 2003
    just buy the oem platinum plugs or other compatible platinum/iridium plugs for longer service life. best to have it done sa casa. you'll be surprised that its not that expensive considering the hassle of removing the intake manifold just to replace the plugs. not to mention that they have to use CONSULT to adjust your timing.
Cefiro Compressor compatible with SR20 compressor?
