Originally Posted by
jick.cejoco
if the a/c system is dormant, both the low and the high side pressures equalize minutes after shutdown. the pressure varies with ambient temperature. using a pressure/temperature chart (you can pull this out from google) for r134a, the pressure of the system should be commensurate with the ambient temperature. if the pressure is lower in the chart than where it is supposed to be with the given ambient temperature, it is low on charge. yes, the suction side will have condensation as the pressure is low and consequently the temperature will be low. as far as the sightglass is concerned, you can not rely on this if the system is using r134a as in your case of a 2011 car. the sight glass has never been an accurate basis for the state of charge and worse with r134a because even if the system is properly charged, the sightglass will always appear cloudy.
