Results 41 to 50 of 54
- Sep 2013
- 505
May 22nd, 2014 02:30 PM #41for me its:
1> turn on engine
2> turn on blower
3> if mainit sa loob, open windows for a minute or two.
4> turn on the compressor, via thermostat. walang a/c button yung fx eh.
i do this to let the engine spray itself with oil, so when i activate the idle up system via thermostat its less wear and tear.
pag ioff naman engine, off muna compressor via thermostat pagdating sa bahay then off ng blower then engine after parking the vehicle. opening the gates, vehicle entry, gates closed, that takes a minute at least. by that time tuyo na evaporator. =)
its more of taking care of the engine (start up) and the vehicle itself (iwas amoy mabaho/kulob).
- Sep 2013
- 505
May 22nd, 2014 05:17 PM #43
I turn on the A/C (fan and compressor) even on cold-starts. The extra load will actually speed up the engine warm-up. Also, the slightly elevated idling will help increase oil pressure to get them moving.
May 22nd, 2014 05:37 PM #45
June 8th, 2014 12:47 PM #46
Assuming your ac unit is working perfectly,kelangan bang I palinis at kung yes,kelan dapat,yearly,2 years?
June 8th, 2014 02:23 PM #47
Mga newer cars Hindi na dapat nag cleaning ng ac system. Kaya may cabin filter na. Para mafilter yung mga dumi. Just change the filter every so often. Kaya usually baklas dashboard na mga cars ngayon kung kailangan mag cleaning. From design niya kasi filter changes nalang dapat.
Posted via Tsikot Mobile App
- Jul 2011
- 1,711
June 8th, 2014 02:33 PM #48Kabitan ng turbo timer ang blower, para pag off mo ng engine ung blower running pa din ng ilang minutes
sent via LaTE Network
June 10th, 2014 12:34 PM #49
Saan mas malakas ang effect ng fuel consumption, Sa high thermostat adjustment to cool, Yung high fan or both. Thanks.
- 54,317
June 10th, 2014 12:52 PM #50
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
