Results 1 to 13 of 13
    Mga sir need help po, my ride is isuzu bighorn problem q pag high speed lets said at speed of 100km/h parang ndi na malamig ang buga ng aircon q unlike pag mabagal lng or kahit naka stop. diba dapat pag high speed mas lumalamig ang aircon kasi mas malakas ang hangin na dumadaan sa condeser, bakti sa akin baliktad nahihilaw ang lamig pag high speed na takbo q.
    tnx
    Apr 2008
    Bro, tingin ko my mga butas yan malapit sa engine bay, malamang di natakpan ng maganda, di ba converted yan, pag nasa high speed ka malakas din ang pasok ng mainit na hangin galing sa engine bay then nahihigop naman siya ng blower kaya nahihilaw ang lamig....
    mabuhay...
    sir sabi ng technician bka daw nag high pressure ang aircon q, dapat daw palitan ang expansion valve. Eto po kaya talaga ang sira?
    Sir wala po sigurong butas kasi minsan naman malamig kahit naka high speed
    May 2007
    Quote Originally Posted by batosai View Post
    You have said that its happened only at high speed but not on low speed. This may sounds like you have a vacuum leak. Check this thing first.
    Sep 2006
    Quote Originally Posted by v6dreamer View Post
    sir pa elaborate nga kung ano yung vacum leak and ano remedyo dito.
    thanks
    May 2007
    Quote Originally Posted by brawlerjack View Post
    thanks
    When I say vacuum leak means relate to your A/C hoses that is most under the dash. Bring your car to any specialized A/C shop to check where that leak is or you could do it yourself by putting colorized A/C leak detector into your system (usually purple color) and locate the purple color where its leaking. Remedyo....well need to replaced what is broken.
    Sir ibig sabihin po ba pag may vacuum leak pati ung preon air ko is nag leak din? Kc kung pati ung preon air ko nag lek din dapat cguro ubos na preon ko kc medyo matagal na po ito.
    Tnx
    Possible na nag high pressure nga. Nag didisengage yung compressor mo pag mataas ang rev mo. Pero not sure kung expansion valve ba ang kailangan palitan dyan...
    Jan 2008
    during high speed, condensers are cooled by the air coming in the engine bay.. possible you have high pressure due to high rev engine during high speed.. check this by revving your engine while at stop make a steady rev at around 2000rpm and check if the aircon cooling disappears.. possible you have a problem on the pressure switch attached to the filter drier.. if there is leak in your system, you will have no cooling at all even on low or high speed..
    you may also have a problem with your expansion valves!! expansion valves main function is to create pressure in the system, when the right pressure is achieved it will release the freon to the cooling coil, absorbing the heat, thus giving you cooler air...(that is why you will hear a hissing sound during the first engage of the compressor) it is possible that when you are at high speed, high rev, the compressor pumping too much, the expansion valves cannot hold the pressure thus releasing the freon prematurely making your cooling "hilaw" or not sufficient..
    May 2007
    Tnx
    No, this is after the reciever that is why your car still have a freon and the A/C working good except on the high speed or uphill.
    Sep 2006
    sir san nakakbili nito pang leak test and san siya ilalagay?
    TIA
    May 2007
    TIA
    Same as where you put the refrigerant or freon, and the tester you could buy into any auto parts supply.
    ok sir I'll ask my technician to check the expansion valve and pressure switch..
    Post q po ulit kung anu magiging findings ng technician ko,
    More power!!
a/c inq
