Need to replace A/C condenser but the only available condenser is a bigger and thicker one. What are the pros and cons of a bigger condenser? Will it make the airconditioning better?
Thanks.
pros - better cooling (surface area of heat exchange is bigger)
- at times may not need installation of an auxiliary fan similar to Nissan's design
cons - more expensive
- may not fit current set-up that may require you to do modifications, ergo, more expense
