Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Results 121 to 140 of 463
    Sep 2012
    ^^^ quick tip to find out if your ac needs servicing. Bili ka ng thermometer tapos i set mo lang sa number 2 then ilagay me thermometer sa vents
    If kaya nya maglabas ng 9 degrees celcius or below sa reading then ok pa yan. Dapat din nararamdaman mo mag cut off sya pag na achieve yung pinaka malamig nyang buga
    Feb 2015
    As per my aunt, they had it already checked, and that's their recommendation, but knowing how "frugal" she is, she did not have it refilled. Now that I'm using it, wanna do it cuz I'm sweating like a pig when using it hahaha - can you advise me how much does it usually cost? Will try the thermometer test, looks doable
    Mar 2005
    Definitely may leak yan. Budget 5-10k. Pag compressor 12-15k
    Sep 2012
    Kung kaya mo dumaan sa Ceejays sa Las Pinas pwede nila i checkup yan for free tapos bibigyan ka ng qoutation ng lahat ng pwede mo ipagawa...
    Prepare ka na lang mga 2 to 3 k for cleaning ang recharge ng freon but if may nakita sila sa leak test then thats another matter altogether
    Feb 2015
    Thanks for the info, kinda pricey, any suggestion along Abad Santos Ave? Those with free check up
    Jun 2013
    Ano kaya problema ng aircon pag nawala buga? Montero ung sasakyan lastweek nawawala na sya tapos biglang lalakas buga. Kanina natuluyan na wala na nalabas,pag sinagad hugong sa dashboard. Para may idea ako bago dalin sa ac shop baka tagain kami sa singil eh. Tnx
    Aug 2009
    Quote Originally Posted by katsupoy View Post
    Sir pa check niyo po yung blower motor, ganyan din po yung nangyari sa akin last time.
    Posted via Tsikot Mobile App
    Jun 2013
    ^ salamat sir. Yun din una hinala ko. Ung katapat kasi namin ac shop sabi madumi daw system,sabi ko naman bagong linis sa bquick. Inexplain ko yung paano nilinis ayoko kasi baklas dashboard. Ang sabi nila wala daw kwenta pag computerized cleaning system. Tama ba yun? Pinakita naman sakin sa bquick after. malinis naman ang evaporator sa lcd. Inisip ko mananaga to
    Jun 2013
    Tinanong ko din sa kanila kung blower nga sira mga 5500 daw. Pwede na ba? Including labor na ata un. Nagtanong ako sa nagbebenta ng blower lang sa ibang shop walang install 3800 blower motor. Magkano kaya aabutin labor talaga nun?
    Jun 2013
    Napaayos ko na kanina sa tropa ko buti dun ko dinala. Resistor block ang sira.may kumalas lang na hinang.hininang lang ok na ulit
    kala ko talaga blower kasi nahugong sa may dash, weird nawala hehe
    Quote Originally Posted by civica101 View Post
    Mga bros,
    I sent my car to Honda cars Kalookan because I heard a pretty bad grating noise while I was driving my car.
    According to them, the compressor had given out, including all the parts inside (bearings, etc.).
    They quoted me around 34K for everything, including cleaning and labor.
    I was thinking that maybe I could save something if I take it to a good aircon repair shop.
    What do you guys think? My wife says CASA na lang daw, para sure but I wanted to hear your opinions. Do you know of a good aircon shop na reliable ang service?
    Appreciate any inputs guys!
    Thanks in advance...
    mahal sir yan... sir mga 20k or sobra pa ung 20k mo magagawa yan palit compresor bago valve at drier at freon
    Jan 2009
    Better get a second opinion. I just had my tensioner and water pump assembly replaced at Honda SPA because the bearings on both were shot and were making a lot of whizzing and grinding noises. Replacing both removed much of the engine noise and even brought out noise coming from the compressor pulley.... Presumably also due to a dying bearing. The car has 75k-km under its belt at 7 years old and this is the first time they were replaced.
    I'm scheduling the compressor pulley replacement this weekend. Though, I'll probably have it done through a third party this time. Honda charges 22k (all in) for the compressor pulley repair kit.
    Jan 2009
    Sorry, it costs approximately 14k... NOT 22k.
    May 2015
    Good Day! ang problem ko sa AC ng car ko (kia pregio 2002 second hand ko nabili) at first.... nawala ang lamig at nawala ung blower sa likod, then ipinaayos ko , need lang ayusin ung relay at wiring.. then kinargahan ng freon, at base don sa technician, oobserbahan daw mga 1 - 2 months if mawawala ung lamig, ok at lumamig ung car kahit tanghaling tapat, pero after a month.. nawala na ung lamig, so i decided to bring it back sa technician, while sa travel going to technician bigla na lang may umirit sa ilalim ng car at nangamoy, at bumagal ang takbo, dahil new lang me magdrive, continue lang ako at pinatay ung blow ng aircon. pagdating sa aircon repair, nawala ung pressure ng freon daw at ung compressor ay nag stuck... at need na daw ireplace ang compressor.. gusto ko sana 2nd opinion, at kung meron kayo maisusuggest na aircon repair na...malapit dito sa San Pablo City, Laguna. Ang ceejay kc ang layo .. d pa ako sanay magdrive ng malayo.. thanks...
    Quote Originally Posted by SirRicomambo View Post
    a tip i received from an insider... don't know if it's still valid..
    them kia compressors can be fixed. as a matter of fact, they used to have replacement parts before, in the casa. it's just that, there is more profit in selling entire units..
    and i was about to recommend my suki in banawe, QC, but...
    May 2015
    thanks po sa reply...
    at sa repair po ng Kia compressor, mas makaktipid po ba ako? saan po kaya repair shop meron ganyan service?
    *to all po
    pede po ba makahingi ng common rates/fee sa ibat ibang Aircon repair services? thanks
    Aug 2009
    Though im from taguig i still go to ceejays. I get what i paid for. Madali naman sila kausap and are giving reasonable discounts.
    Feb 2014
    Ceejays the best, likod lang inuupahan nmin house dati kaya pg pumalpak ac lapit lang hehe..
    Jun 2009
    Hi Folks, I am a new/old member (matagal ng member pero di new lng mag post).
    anyway, i just for a honda city - 2011, ok pa naman ang aircon nya, malamig pa naman pero sabi nung may ari di pa daw na papalinis. questions:
    - do i need to have it cleaned? kinda oc since 45k na din tinakbo
    - what are the basic things na gagawin? i need to ask sa inyo para di ako maloko..
    - how much typically would it cost?
    TIA
    TIA
    Dec 2002
    Kung malamig pa naman buga nya huwag mo na ipalinis, ride ko since 2008 hindi ko pa napalinis aircon. Yung aircon filter lang pinapalitan ko.
Best Aircon Repair Shop?
