Results 1 to 4 of 4
    Oct 2009
    what could be the prob? ac po ba? thanks.
    any recommended shop? hehe
    it's the actuator makes the engine idle up when the AC is on/compressor engaged, check the actuator for troubles.. "baka" sira na po.
    its the Idle Air controller valve have it inspected and cleaned. Have your throttle body cleaned also.
    Nov 2007
    sir maaring pa check nyo throttle valve or yung cirvo kit..isa pa maari ring sa air con prob..subukan nyo muna ring pa check or babasa low at high pressure side ng a/c system...salamat
bagsak rpm when ac is on?
