Results 1 to 10 of 11
- Jun 2013
- 188
June 9th, 2013 01:02 AM #1I noticed that my car's AC is blowing "smoke". Is this normal or does this mean that there is a leak in the freon? If there is indeed a leak, how much will this cost to repair?
TIA!
June 9th, 2013 02:25 PM #2
June 9th, 2013 02:39 PM #3
- 54,290
June 9th, 2013 11:48 PM #5
condensing water vapors exiting the a/c registers is normal specially when the relative humidity is high and the ambient temperature is high. if the a/c is still doing its job, it is no problem as long as you can control the temperature. if it gets uncontrollably cold you can shut if down manually until you get it diagnosed and repaired. the a/c is not designed to work like a refrigerator nor like a freezer. it is there for comfort of the car's occupants
- Nov 2008
- 641
June 10th, 2013 10:42 PM #6Sir velOcity,
May I ask as to when was the last time you have your car's A/C serviced? Other than the suggestions / discussions given by our Tsikot guru's above, your ac system (evaporator) might be already dirty causing the restriction of air. Air restriction sometimes causes the coil to abnormally reach very low temperatures (specially if the temp settings are very low / or max) causing very high temp difference between the coil and ambient, thus the smoke.
June 10th, 2013 11:22 PM #7
bkt kahit bagong a/c ng bahay mga sir ganun din may whitesmoke siya tapos dna naulit
- Jul 2011
- 1,711
June 11th, 2013 09:00 AM #9Wag lang Sir ung usok ng bus/jeep sa harap mo ang pumapasok sa cabin, baka ung air intake selector mo e nag auto sa FRESH air.
In some models: "To prevent fogging up of the windshield, the air intake mode may change automatically to FRESH depending on the condition of the air conditioning system."
- Jun 2013
- 188
July 3rd, 2013 02:10 AM #10
Are they on track to surpass last year's sales?
Car Sales Data (2025)
