The 460 received the following evaluation:
"The 460 substitutes a generous boot for the 440's tailgate but is otherwise identical. Liked by older motorists for perceived Volvo strength and safety, but lacks image and now sells for less than the hatchback. Power steering is a must - parking can be heavy going without it. As with the 440, models from late 1993 are best." [5]
Parker's also takes note of problems commonly reported by owners over many years. It summarises the issues found in relation to the 400 series as follows:
"Some early cars suffered from erratic build quality; possible rust in body seams; gear linkage failure; overheating; coolant leaks; smoky engine when cold indicates piston wear; possible electrical problems."
It should be pointed out that the data used to create this list came predominantly from owners of the earlier Mark 1 models of the car, with many of these faults becoming much more rare (or disappearing completely) with the introduction of the Mark 2. An auxiliary water pump was added to all non-turbo models from late '93, along with 'run-on' electric radiator fans, which continued to run after the engine was switched off in an attempt to fix the overheating/coolant problems...
