Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 121 to 140 of 220
    Apr 2012
    Currently here palinis aircon ng commuter ko. Pangalawa na sasakyan ko na to sa kanya. Mura ang service, maayos at mabilis [emoji4]
    Sent from my SM-J730G using Tapatalk
    Apr 2017
    hi sir, paano ma contact si mang danee ty
    Apr 2017
    success service done!
    Dec 2015
    Quote Originally Posted by cjcrystal View Post
    Sir pa kwento naman yung scope of work ginawa sa ride mo and how much labor and parts. TIA
    Sent from my ASUS_X018D using Tapatalk
    Oct 2015
    I can attest to my satisfaction of the services rendered by the legendary Mang Danknee, na di tulad ng iba na banat agad ng palit sa presyong taga, si kuya Danny, nag rekomenda kung makapag antay daw ako next day may makukuhanan syang mas murang compressor (which is really shot na, pag tingin nya tumatagas na langis). Hanggang ngayon ilang buwan na tumatakbo pa din sa lamig
    May 2015
    Just came from mang danny this morning to have the condenser fan installed, pulley shim removed/adjusted and freon recharged. All in for 600 pesos. Sulit na sulit [emoji108][emoji3]
    Nov 2018
    Quote Originally Posted by shiro View Post
    Ako rin kakapagawa ko lng kay mang danny sa seaoil. Bawas magnetic clutch shim lng for crv gen3. 20-30mins lng ginawa at mura pa. Mabait pa si mang danny. Observe ko dw muna since possible din dw ung sensor ng compressor pg umulit. He is there dw everyday. Still the same number posted in this thread. Thanks to everyone who posted here! Big help to find mang danny!
  8. #8
    Apr 2009
    Share ko lang...nagpagawa ako ng aircon kay Mang Danny over the weekend. Satisfied customer here
    nauubos ang freon ng car ko and hindi ma trace ng aircon repair shop near our place, 2 months na ako pabalik balik
    sa kanila. after the fourth freon top up, dinala ko sa ibang aircon repair shop...ang quote sa akin almost 20k !!!
    i texted and booked with Danny (got his celno from this thread), we met early morning sa Seaoil. he found the leak, had the hose replaced, and did a retest. he worked on it for about 3 hours and charged me 2,850 pesos. i will observe in the next 2 to 3 weeks, pag hindi nagbago ang lamig then the leak has been fixed.
    highly recommended, you just need to text him to set an appointment, nakikipuwesto lang sya sa Seaoil and he pays the gasoline station cashier a certain amount and they let him use a corner near the toilets.
    hope this helps.
    Aug 2018
    My batman vios had a scandalous squealing noise from a cold start or a stop lalo na kapag may a/c (so I drove around without an a/c). I tried the test suggested on YouTube to spray water on the belt to see if it goes away and it wouldn't. From reading related threads, it could be from different things (belt, bearings, pulley, magnetic clutch, urgh) and because I don't know anything about cars, I knew I had to go to a trusted a/c mechanic. I "booked an appointment" with Mang Danny and when I got there, there was already another customer (the girl on the picture) but there's a spot reserved for me. He checked my car right away, tightened the serpentine belt, checked the A/C and showed me (from the meter he was using) that it is fine. Pabugahan ko lang daw ng tubig sa car wash yung front grill para luminis. He didn't charge me anything and won't accept even a tip, maybe because to him he didn't really do anything. I hope I'm not advocating that people abuse him because "he doesn't charge" for little things. I'm only saying this is one honest and helpful guy. [emoji106]
    Also thanks to travajante and dreamur.
    ok din si kuya.
    saan pala location iyang seaoil na pinag gagawan niya?
    Aug 2018
    ok din si kuya.
    It's along Pasig Blvd. If you're coming from Rizal Medical for example, nasa right side siya and before kumaliwa ng Shaw Blvd makikita na yung SeaOil.
    May 2010
    Nag palinis ako sa kanya non sabado. Mahina na yun lamig ng aircon pero fully functional pa (walang break down kahit tanghaling tapat or El Nino pa kaya ang decide ako palinisan sa kanya. Tinawagan ko sabado umaga at 1pm pumunta ako sa SeaOil. Tapos na yun isang customer niya pagdating ko so ako na agad!
    Unit ko is Innova Gas 2009 M/T 121K+ km. First time malinisan ang aircon. Alaga lang sa filter palit once a year linis every 3mos. Hindi binaklas yun dashboard . Glove box at yun plastic lang sa manibela yun tinggal at nadinukot na yun fan at evaporator. Sa likod na aircon naman ay binaklas yun right side plastic "wall" (gilid ng last row na upuan) pati yun right side part ng rear bumper para madukot yun evaporator at aircon assembly don.
    Wala naman tagas or langis sa 2 evaporators (front rear). Kadiri lang yun evaporator kasi parang malapot na plema yun dumi . Binugahan na lang ng tubig galing sa pressure washer. Hindi na nilagyan ng solution agent kasi baka masira daw ng maaga yun evaporators (may mga tama na kunti mga fins pero ok pa daw). Nag top-up din ng 3 silicon oil/gel sa fan at palit filter drier. 3 hours yun gawa 3 sila.
    Cost:
    * Labor + Filter Drier - 4,500.00
    * 3 pcs Silicon Oil - 180.00 (60 x 3)
    * 1 liter coolang (natapon kasi non tinggal nila radiator hose para madukot yun fan) - 202.00
    * Tip - bigyan ko na lang daw isa nyan mekaniko na nagkalas ng fan
    Total - 4,680 + 202.00 + Tip.
    Balik lamig ulit aircon ng trusted innova ko.
    Salamat!
    What's a batman vios?
    Aug 2018
    Second gen
    Feb 2017
    Hi,
    Is his shop still in Seaoil along Pasig Blvd. area? Need to contact him and have my aircon checked.
    Sent from my ONEPLUS A5010 using Tapatalk
    Jul 2005
    Quote Originally Posted by 94mitsukid View Post
    Hi,
    Yes. Still the same gasoline station.
    Jul 2005
    Quote Originally Posted by retsmd View Post
    A week ago, I had a brand new compressor installed on my Sport Trac He charged me less than 2k for everything.
    Feb 2017
    Okay bro. Texted him. Hopefully mapagawa ko with him mamaya. Nawala kasi ung freon kahapon eh while going to work
    Feb 2017
    Finally, I met this legendary Mang Danny. Got a brand new magnetic clutch, oil hose for the compressor, freon and charged me less than 4,000 pesos.
    Lamig na ulit sa sasakyan [emoji4] nalibre pa ako ng B'lue flavored water.
Another Aircon Repair Shop : Danknee
