Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 220
    Oct 2004
    #41
    doesnt that "amplifier" have an effect on the idling of the car also? aren't they all interconnected somehow?
    Aug 2004
    #42
    Not really kasi ang thermostat just switches the compressor on or off depending on the cabin temp. Pag-on or off ng compressor the engine will detect the increased or decreased load and adjust the RPMs accordingly.
    BTW mukhang may magic na gagawin sa thermostat ko. May nagsabi kasi na wala daw syang mahanap na thermostat sa Evangelista. Some people recommended looking for a potentiometer. Will this suggestion work? Or tanong ko na lang kay Danny hehe :D
    Oct 2004
    #43
    seminarista: baka maging eroplano na yang car mo at makalipad na siya! =) but i would be interested to know if it works.
    Aug 2004
    #44
    Visited Danny last Saturday. Here's what they did:
    1. Cleaned evaporator
    2. Washed and cleaned blower housing.
    3. Added foam to blower housing edges. Added more foam to blower doors to prevent fumes and stench from entering the cabin.
    4. Washed and cleaned compressor.
    5. Replaced compressor bearing. Also replaced housing O-ring.
    6. Replaced drier.
    7. Flushed all aircon lines to remove all traces of R12 oil so I won't get into trouble with the LTO next year.
    8. Reassemble, refill with R134 and leak test.
    He didn't touch my thermostat since he said it's the original unit pa daw. If it isn't working pa rin he'll look at the thermistor next time. Kung ayaw pa rin saka na magpalit ng thermostat.
    90 day warranty. Birthday pala ng anak nya nun so nakikain pa ako ng ice cream hehe.
    Total cost? Around 3500.
    Verdict: Highly Recommend.
    Addendum: Danny is very environmentally-conscious so prepare for a lecture if you're still using R12 ;)
    Jan 2003
    #45
    Quote Originally Posted by SeminaristaKuno
    6. Replaced drier.
    so you spent 3500 to convert from r12j to r134?
    how's the cooling? sabi kc mas mahina magpalamig ang r134 kaysa sa r12
    Aug 2004
    #46
    It feels cooler because everything was cleaned and the cabin is now effectively sealed from outside hot air. I can't really say if the refrigerant is a factor because I was using R134 on R12 oil for 1.5 years.
    #47
    Spoke with him din last Monday, pinacheck ko lang yung bearing, babalik ko nalang for full cleaning since mawawala din freon.
    Very humble guy to talk to.
    BTW, it's not Dang-kee ang basa ha hehe, DANNY = DA-KNEE (tuhod)...
    Parang TheVeed hehe DA-VID
    Oct 2004
    #48
    okay thanks, theveed. will certainly keep that in mind. by the way, meron ka bang shop or are you just an avid tsikoteer? kung meron, saan and what is your specialty?
    #49
    jayelgee: it's in my signature below...
    #50
    Question: Can you use R12 in a compressor that uses r134a? Kasi nagpalit ako ng compressor Denso. The whole system (before the change of compressor) uses r12. I changed the compressor which uses r134a. But I am still using r12. Tama ba? thanks
    Oct 2004
    #51
    Quote Originally Posted by theveed
    oh, thanks theveed...
    as for the name of the shop of danny, hindi ba Danknee?
    #52
    estee: Please do a search on R12 to R134a conversion, naka list dun kung ano kailangan palitan.
    Dankee nga, what I meant is it's pronouced DANNY (dah-knee as in tuhod). Kaya Danknee.
    Oct 2004
    #53
    O, "Dankee" naman ngayon! I figured you meant the pronounciation nga. I used to pronounce it DANK-NEE...yun pala, DAN-KNEE dapat...thanks for clarifying that for me.
    Feb 2003
    #54
    panalo talaga itong si mang danny! went there to have my a/c checked.
    very trustworthy. highly recommended.
    Sep 2004
    #55
    thanks sa recommendation na ito...will visit him w/in the next few days...mlayo ksi sakin yng other recommended aircon shop na Mang Mario...
    keep it up tsikoteers!
    Feb 2004
    #56
    ok tong GUY nato. 1st thread pa lang nito -- pinuntahan ko na. magaling at xplain nya ang bwat gagawin. sya lng ang nka-ayos ng a/c ko. ilang paayos na din ako nun kng kani-kanino.
    me leak sa condenser ko(pinutol then palit), at replace xpansion valve + relay para sa compressor.
    Oct 2005
    #57
    Quote Originally Posted by jayelgee
    Ningaskugon, the name of street his shop is on is West Capitol Drive. Coming from EDSA, take Shaw going towards Pasig until you hit the rotunda where you'll see a Petron station on your right, a street, and a BPI and Mercury Drug accross the street from Petron. That street is West Capitol Drive. Take West Capitol Drive and you will see DANKNEE on your left. Maliit yung sign, so be careful not to miss it. If you hit the next major intersection (w East Capitol Drive), lumagpas na kayo. Double back na lang.
    ummm...do i have to follow the rotunda? i'd like my compressor to be checked up kase maingay eh...parang may secondary motor na umuungol pag nag auto-on ang aircon...
    Aug 2004
    #58
    Ikot ka lang sa rotonda until you see the Petron gas station and Mercury Drug. Pasok ka sa street na yun. May guardhouse sa labas pero la naman bantay. It's the street right across Pasig City Hall. Once you're there Danknee's shop is on the left side. It's right beside a restaurant that looks like a kubo.
    Oct 2005
    #59
    ahhhhhhhhh ok...salamat!!! pupunta na ako dun...duda ako sa estimate dito sa aircon shop malapit sa amin...3500 daw ang palit ng bearing + cleaning ehhh...may nabasa ako dito somewhere sa workshop 1500 lng daw yun kay mang mario...
    Sep 2004
    #60
    Quote Originally Posted by umzzzzz
    hi sir...npa-ayos mo na ba aircon mo?..based sa kabilang thread d2 mgkapareho tyo ng symptoms eh...
    pa-post ng updates!...thanks!
Another Aircon Repair Shop : Danknee
