Results 1 to 20 of 24
    Jul 2006
    tanong kolang po kung ano pong gamit niyong radiator cooling additive?
    gumagamit ba kayo o hindi?
    Jun 2006
    may iba pa bang cooling additives sa market? isa lang alam ko eh "ethylene glycol" lang gamit na coolant sa radiator... sa ibang bansa tawag nila doon "antifreeze"
    yes may coolant sasakyan ko...
    Please refer to the other coolant threads.
    Yes, I use 50% ethelyne-glycol based coolant. Castrol was the brand the last time around. Whiz naman dun sa Vitara.
    we don't use coolant additives... absolute lang, never overheated...
    Sep 2004
    i think its better to use coolant with anti-rust feature kasi non-sense ang anti-freeze dito sa Pilipinas.
    i use prestone coolant in my patrol.
    Jul 2006
    Quote Originally Posted by normanenoza View Post
    Anti-freeze prevents it from freezing by lowering the freezing point, as the name implies. Also, anti-freeze increases the cooling system's boiling point. This is very effective in hot climates so the cars can run more efficiently than with just plain water. Check the boiling point levels of ethylene glycol and compare it to water (100 deg C).
anong gamit niyong cooling additive?
