Results 1 to 10 of 52
- Sep 2007
- 20
September 21st, 2007 09:22 PM #1Fellow Tsikoteers,
May Civic ako 2000 model.Here's the problem 5 months ago tumataas ang temp ng car so i had it check sabi Radiator needs to be overhaul,so i had it overhauled so after a week bumalik sa dating sakit,when the other mechanic pina check ko Thermostat daw sira na so i had it replace OEM.Sira nga naman medyo napa bilib ako.ngayon naman tumataas na naman ang Temp ng car. i dont see any leaks whatsoever sa mga radiators,hoses,waterpump etc.eto pa ang weird bat pag gabi lang tumataas when i think di na gaano mainit non.so i turn of the air con medyo bababa pero babalik din sa dating mataas na temp.Guys What do you think is Wrong.Sa umaga okay naman pag gabi lang.Pls HELP!
THANKS SA LAHAT,Godbless
September 21st, 2007 09:31 PM #2
Try pa check ang Aux fan baka mahina na ang ikot, maluwag ang conenction kaya iontermittent ang operation.
- Sep 2007
- 20
September 21st, 2007 09:49 PM #3Thanks That sounds good..Kasi yung tinanungan kong mechanic.sabi nya check nya raw ang fan ko baka mahina na nga raw ewan ko sa pagi kot o ano...basta sabi nya sa fan muna raw..Thanks..
BANNED BANNED BANNED
- 3,790
September 21st, 2007 10:02 PM #4nagaagawan ng koryente pag gabi - sindi ang ilaw kasi...so the fan is not getting enough juice...unlike sa umaga na solo ng fan ang current. tapos the a/c fan aids it pag naka-on ito sa gabi....
question is 2 ba ang fan niyan - one for a/c and another one the normal fan?
- Sep 2007
- 20
September 21st, 2007 10:14 PM #5Wildthing,
Yes one sa aircon,one sa radiator fan..
Thanks for sharing all your views...
September 21st, 2007 10:15 PM #6
Aux fan po yan since nagooverheat sya pag nakabukas aircon. Sira na po yung carbon brush ng aux fan mo po or baka loose connection lang.
September 21st, 2007 11:25 PM #7
sa umaga ok ang aircon hindi nagoverheat at sa gabi lang nagoverheat?
try mo rin pa check temp sending unit at temp sensor gasgas narin tong sagot ko hehe share ko lang medyo parehas tayo ng symptoms e pero pacheck mo muna yung fans
mas affordable kasi yun e hehe
- Sep 2007
- 20
September 22nd, 2007 08:51 AM #8Fan na lang nga sana.pa check kuna ang both Radiator at Aircon Fan.Thanks To all..later say ko ang results..
Thanks
September 22nd, 2007 09:09 AM #9
share ko lang experience ko sa ek. symptoms na sira or nagloloko ang aircon fan, pag slow matraffic, nawawala ang lamig ng aircon, and then pag mabilis na takbo ng oto lalamig ang aircon meaning cool air is blowing the condenser. ang maganda dito sa civic hinde basta nagsisira ng parts. after ko mapalitan ang aircon fan , solve na problema.
try mo sir ipa check ang thermo switch, naging problema ko na din ito dati, maganda talaga naaagapan at hinde lalala ang sira.Goodluck.
- Sep 2007
- 20
September 22nd, 2007 11:43 AM #10Sorry for the ignorance.Saan pwedeng pa ayos?sa mga Auto electrical ba o sa mechanic?Thanks
Life Lessons From A Monk & His Tuned Mini Cooper S - Speedhunters Sent from my SM-S901E using...
Monk-owned R53
