Results 11 to 20 of 52
September 22nd, 2007 11:49 AM #11
*Lerual: Taga saan ka po ba? Kung sa north ka sa shop ni Mang Mario or kung sa south ka yung aircon shop malapit sa Metromall Las Pinas. Maige kung sa aircon specialist ka magpacheck since ang culplrit ng problem natin is most likely the aux fan.
Tama din po ito, sa mga aircon specialist kaya nila tignan yan.
- Sep 2007
- 20
September 22nd, 2007 12:18 PM #12Pasensya na sa lahat..Taga Pampanga ako..matagal na akong pa tingin tingin sa tsikot at nagbabasa sa mga threads dito at kahapon lang ako nag register..first time ko kasing magka kotse.hehehe dito kopa kabisado paano i edit ang profile ko.Thanks Sa inyo at Patience..
September 22nd, 2007 12:25 PM #13
September 22nd, 2007 01:02 PM #14
have your alternator checked. parang electrical prob yan kaya ooverheat,e...
either replace mo with a bigger capacity na para sulit na..(90AH max for stock system)
September 22nd, 2007 04:50 PM #15
my 2cents; if the fans are bad it will cause overheating all the time. modern cars (not sure about honda though) use the ect and ac pressure transducer as input to the pcm. the pcm will duty-cycle (pulsewidth modulation) the fans depending on the ac head pressure and ect temp (sometimes the fan is running on low speed and sometimes running 100%). driving at night will not cause the head pressure to rise considerably and the pcm based from the inputs of the ect & transducer will not command a high-speed fan, so i think there really exist a problem that requires further diagnosis. (again this is just my 2cents)
- 285
September 22nd, 2007 09:12 PM #16check your radiator cap na din bro. baka nagbo boil ang water sa reservoir tank, kaya nag uubos ng tubig, kahit wala namang external leaks.
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 23rd, 2007 03:22 PM #17had the same problem before. replace all the ground wires of the car and clean off the surfaces na pinaglalagyan. mali lang signal pinapadala nyan sa gauge mo.
- Sep 2007
- 20
September 24th, 2007 09:05 AM #18Guys,
Mukha ngang walang marunong sa pampanga naglibot ako last saturday and sunday nagugulat pa ang iba bat daw pag gabi lang..meron pa sa signage nya expert from banawe pero di rin alam.Di alam ang sakit ng kotse.nawawalan tuluy ako ng gana...Dami nating suggestions pero ill take them one at a time..Thanks Guys..
September 24th, 2007 09:28 AM #19
Simple lang naman malaman kung mahina ang ikot ng fan. You can even do it yourself. Just pop the hood and engage the aircon. Pag mabagal ang takbo ng fan, yun na yun. Pero since the mechanics you've been to has seen your car, hindi siguro fan ang problema. They would have diagnosed the problem easily.
Baka naman yung temperature sending unit or yung mismong gauge ang may tama? That is, kung wala naman leaks sa cooling system or kakakibang usok mula sa muffler.
- Sep 2007
- 20
September 24th, 2007 10:07 AM #20na try kuna yun makita ang mga fans umikot parehas naman mabilis umikot.di rin nauubos ang reserve water,di rin kumukulo,no white smoke,di sira ang radiator cap palitan kuna rin for assurance. Si speedyfix try ko yung sinabi nya.change the ground wires and clean,tapos pa check ko ang gauge
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
