Just want to share this shop I found along Makati. I was planning to go to Denso along Pasong Tamo ext. and good thing I took the long way to go there and were able to notice this Car Aircon Shop almost at the corner of Pasong Tamo and Arnaiz (Pasay Road). The name of the shop is TOWER OF DAVID. It is just right in front of Makati Cinema Square.
I went there instead since it was already 5pm and it is Sunday, I saw their gate was still open and decided to ask how much for a gen. cleaning for my AC unit. They told me it is 1,5k compared to that place I went at the corner of Pasong Tamo cor. Edsa. (forgot the shop's name) is a bit cheaper. So I decided to have my unit service by them since it's already late and thinking I might not make it if I insist of going to denso at that time.
I told them my problem, water is leaking inside my car after few hours of turning my AC on, during noon time my AC seems to have a hard time to cool my car, and told them the previous observation of that shop in edsa that my thermostat is busted already and it is making my compressor go non-stop. They told me they won't be able to tell me exactly the problem of my unit unless they pull it down. So I told them okay do the cleaning and we'll go from there. They even asked me for a confirmation if I really want to have my unit done (made me think they are not one of those shop who is only up to the clients money)
They started by checking my freon charge and told me it is almost empty and showed me the gauge to prove it. I asked them I just got it serviced from that place in edsa and they even used this machine which recycles freon. They said there might be some leak on my evaporator but they still need to check on that. I already told them that shop advised me to change my expansion valve and that other valve to fix the problem. (which I did)
While they were removing some bolts to pull down my AC unit I was asking them question about that previous diagnostic from that shop in edsa about my compressor not going automatic and it might be my thermostat., they said thermostat (sensor) if it is really not busted we really recommend for the owner to get it from casa coz that is the only place they can get it, they also mentioned they can get it for me but if I have contacts I might be able to get it cheaper than them.
When they pulled out the unit it was all dirty and the foam lining are all banged up! They noticed I still have the stock foam installed and it should have been replaced when I got the unit serviced. They were fast, they can even do the job with their eyes closed. They cleaned the fan, my evaporator and the whole casing for the unit. They checked the evaporator for some leak by filling it with gas and submerging it in a tub of water. There was no leak!
They put everything back together and it only took them 30mins to service my AC unit and they fill in new freon for free... and also the replaced all those foam lining inside on that flap next to the blower.
Finally they checked if the thermostat is really working and they said it is working!!!
I will never go back to that shop in Edsa cor. Pasong Tamo!!!
I will highly recommend TOWER OF DAVID to service your AC unit. You can even eat pares/bananaque/kamoteque while waiting, there's a lot of vendors outside of their parking/service area. The place is simple, neat and people there are friendly, plus the dogs too are friendly :D
By the way, they also have towing service.
