Results 1 to 12 of 12
  1. #1
    good day peeps! tanung ko lang what could be the cause when sometimes i turned on the aircon both front and rear eh mas malamig ang rear a/c? Pag front lang ok naman ang lamig pero bakit pag dalawa na ang gumagana parang nababawasan ang sa harap? baka me naka-encounter na nito pakipost na lang kung na solve nyo na or what could be the cause, tnx.
    It's true for vans and AUVs which have 2 evaporators... Malamang kulang ka na sa refrigerant (freon or R134a)..... Anyway, since I see that you're from the south, if you like your aircon checked thoroughly, you can go to Cee Jay's here in Las Pinas (along Zapote-Alabang Road) just after Makro and Uniwide MetroMall.... Okay sila!
    5505:home:
    Aug 2007
    naexperience ko na ito sa aking '07 L300 versavan dual aircon mas malamig sa likod compare sa harapan nung pinacheck ko sa CASA hinugasan or nilinis lang yung filter dahil sobrang dumi then after that back to brand new na uli. P600 pesos pala yung labor every 3 months ko daw palinis to maintain yung lamig na gusto ko MITSU BALINTAWAK ako nagpapaservice
    Nov 2006
    Was about to make a new thread about my problem but this one is similar to what I am experiencing... but in my case, the front aircon only "cools" when the rear aircon is turned on. Also, the rear aircon is always cooler. Also, what can be the problem if my aircon stops cooling when stuck in traffic, but when the van is moving, it cools up? Many thanks!
    BTW, I'm using a 1996 L300 van...
    Nov 2007
    Quote Originally Posted by leadbelly View Post
    check the aux fan at the condenser unit, it might not working properly kaya when u stuck in traffic nawawala ang lamig then when the van is moving the a/c goes normal meaning aux fan ng condenser mo ang may problem. Kelan mo pa ito na-experienced? kung matagal na check the level of freon kasi kung matagal na yan sigurado nagkulang na ng freon yan dahil baka nag-high pressure na ang compressor mo. kapag kasi hindi maganda ang cooling ng condenser ang tendency mag high pressure ng compressor at magdischarge ng freon.
    re problem sa rear a/c pa-check mo muna yung unang nasabi ko then to folow na ito, as i said kung kulang ng freon maaring front or rear ang mawawala ang lamig.
    Nov 2006
    Thanks esnie.com! I'll check the auxiliary fan first. I experienced this dati pa, actually, the first time i had my aircon "fixed" ganun na problema. Btw, how do I know if the aux fan is working properly? Also, how do I check the freon's level? (Sensya na, i really know nothing about automobiles...) Pag daytime, lalo na pag hapon, sobrang init talaga, di kaya ng aircon. pero pag gabi or tagulan, malamig naman... may kinalaman din ba to sa condenser? Thanks again!
    Apr 2010
    UP po for this one.... encountering same problem in our nissan urvan.. thanks!
aircon question for dual aircon vans, warm front cool rear
