Results 1 to 8 of 8
    Jan 1970
    yesterday nag overheat yung oto ko... di naman tumirik, naubusan ng tubig sa rad (nakalimutan ko ilagay yung takip ng coolant reservoir -- oo alam ko katangahan talaga!). nong nag mainit ang makina.. may lumalabas na white smoke sa may muffler.. as in parang cloud talaga... pinatay ko ang makina (dahil maski anong buhos ko ng tubig at dagdag ng tubig sa coolant reservoir, ayaw bumaba ng temp).. pinalamig ko... checked the rad (konti na lang ang tubig.. coolant na lang ata ang natira) pinuno ko ng tubig, pati yung coolant reservoir. ayun ok naman... normal ulet temp, nakauwi ako ng bahay na di nag ooverheat, sa tingin ko talagang naubusan ng tubig dahil sa katangahan kong di nasara yung reservoir, plus wala na reng white smoke na lumalabas sa muffler ko. isang problema ko, when i checked sa ilalim, parang may tagas ang makina ko (there are a few drops of oil sa floor). what should i do? anong problema? first time ko lang makaranas ng overheat. did i break something? the car is running fine naman. thanks for the help guys
    When your car overheats, its adviseable to change the oil right after as its molecular buildup can break down when the engine overheated.
    Just hope that you didnt damage any internals when you overheated (this may occur at times). Try to change the oil then observe your car for any leaks or oil consumption/loss and spark plug fouling. If there is any such problems, try to get a engine compression test as well just to be safe.
    Jan 1970
    vinj, pre thanks for the inputs... i will do what u said. so far the car is running fine. no overheats and white smoke whatsoever.
    Some engines tend to self adjust their tuppets after an overheating stage. Try to listen for some unwanted noise under the valve cover.
    Jan 1970
    ungas, thanks tol.
    just went to a mechanic a while ago, he told me i need to replace the head gaskets and oil seals, parang top overhaul ang gagawin. tsk tsk ... gastos talaga
    Oct 2003
    malamang overhaul na nga talaga yan--- patay kang bata ka laki na naman gastos--- ganyan din kasi ako dati kamamadali hindi nailagay yun takip eh di todas!!
    Changing the gaskets shouldnt be that costly IMO... Canvass muna from diff shops.
    Try to get also a second opinion from another mechanic just to be sure... especially if you dont see any leaks in the engine area.
    Jan 1970
    had it checked sa ibang mechanic, sabi nya all it needs are new oil seals (for cam and crankshaft), tinaas nya yung oto at chineck ng mabuti... so far mukang mas kapanipaniwala sya kasya yung isang mekaniko na mukang gusto lang maka-uto
white smoke sa exhaust when overheat
