Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Jul 2006
    tanong kolang po kung ano pong gamit niyong radiator cooling additive?
    gumagamit ba kayo o hindi?
    Jun 2006
    may iba pa bang cooling additives sa market? isa lang alam ko eh "ethylene glycol" lang gamit na coolant sa radiator... sa ibang bansa tawag nila doon "antifreeze"
    yes may coolant sasakyan ko...
    Please refer to the other coolant threads.
    Yes, I use 50% ethelyne-glycol based coolant. Castrol was the brand the last time around. Whiz naman dun sa Vitara.
    we don't use coolant additives... absolute lang, never overheated...
    Sep 2004
    i think its better to use coolant with anti-rust feature kasi non-sense ang anti-freeze dito sa Pilipinas.
    i use prestone coolant in my patrol.
    Jul 2006
    Quote Originally Posted by normanenoza View Post
    Anti-freeze prevents it from freezing by lowering the freezing point, as the name implies. Also, anti-freeze increases the cooling system's boiling point. This is very effective in hot climates so the cars can run more efficiently than with just plain water. Check the boiling point levels of ethylene glycol and compare it to water (100 deg C).
    Sep 2006
    Quote Originally Posted by mbeige View Post
    Mbeige,Do you use Zerex or MB coolant on your W123?
    I used Castrol the Protector Series Coolant
    267/Liter mas mura ng konti sa prestone.ok naman sya.
    Jul 2006
    Quote Originally Posted by m_ron View Post
    They're the same.
    But I got the MB bottle, I didn't know there was a NAPA store nearby that sold the Zerex brand.
anong gamit niyong cooling additive?
