Page 1 of 2 12 LastLast
Results 1 to 10 of 21
    Jun 2006
    Quote Originally Posted by jvdejesus05 View Post
    guys got a prob with my aircon... bigla nalang nawala yung lamig... had it checked yesterday sa isang maliit na aircon repair shop, wala na daw freon and baka daw may leak... gusto ko sana magsecond opinion sa iba at kung ipagawa ko man gusto sa tried and tested na ng mga taga-tsikot... san po ba maganda?
    sasakyan mo ba adventure? kung ganoon para makasigurado ka dalhin mo sa mitair sa quezon avenue, iyun nga lang medyo mahal ang parts pero sigurado original naman ang parts na ikakabit nila sigurado malamig ang sasakyan mo at walang sakit ng ulo...
    hirap kasi pag sa labas or kung kani-kanino mo lang ipagawa iyun aircon mo... galing na ako diyan kaya stick to original mitsubishi parts lang ako...
    Try mang mario. Totoong trabaho walang lokohan. mura pa!
    Mar 2004
    Is this normal?
    i would hear the compressor click and after a split second it would click again (interval between clicks is less than or equal to 1 sec), these would go away and later you would hear it again.
    thanks for your inputs
    Quote Originally Posted by Fulcrum View Post
    Is this normal?
    thanks for you inputs
    When that happened to me, the a/c magnetic clutch was about to say goodbye. Your results may vary.
    Mar 2004
    repairable pa ba ang magnetic clutch?
    Sep 2005
    aba! meron din ako nyang click-click intervals. kung magnetic clutch po ito, magkano pagawa? kay mang mario ba kaya? tia
    Ano ba ang Php800+Php600? Parang ganun ata dati nung nagpapalit ako. Yung coil mismo is Php800.00, the labor and other stuff, Php600.00.
    Ewan ko lang kung nagkaron na ng inflation. hehehe.
    Sep 2005
    Is this normal?
    pwede din sir sobra sa freon nag high pressure sya...
    pacheck nyo sir baka may idamay pa yan. lalaki gastos
    Mar 2004
    Is this normal?
    I also noted that after driving high speed, as i slow down the air would become warm, not hot. The cold air will become warm by as much as 40% temporarilly and will revert back to the cool air in a matter of seconds. I find this disturbing because it doesnt happen in the other cars I drive.
    post of attic_dude
    napapansin ko, pag naka stop ako ng matagal hinde na lumalamig yung aircon ko. pero once umaandar na ako, malamig na malamig siya. consistent na siya na nangyayari, napapansin ko yan lalo na kung traffic. halos parang naka fan na ako, pero once umandar na ako ng medyo malayo, lumalamig na siya ulit.
    any thoughts guys?
aircon problem
