Results 1 to 3 of 3
    Mar 2007
    Mga master meron akong Toyota Corolla XL 1997.
    hindi ako satisfied sa lamig ng aircon ko pag makulimlim malamig sya pero pag mainit at tirik ang araw mainit sa likuran,
    pina check ko ang sabi barado raw kasi yung dulo ng aircon sa makina papunta sa loob ng sasakyan pinahawakan sakin nagyeyelo sa lamig barado raw yun sabi papalitan daw yun at yung maliit na parang bote pasensya na newbiw lang sa sasakyan. hindi po ba pwede ipalinis lang ito, or kailangan talaga palitan?
    ah expansion valve yun replace na lang para mas accurate .
    Feb 2009
    Quote Originally Posted by majorpain30 View Post
    the "maliit na parang bote" is the receiver/dryer. if this was freezing, it is an indication that the dryer element is saturated with moisture and is frozen and moving the superheat region by the restriction before the expansion valve. the only fix to this is to evacuate the system and replace the receiver dryer and recharge with fresh compressor oil and refrigerant if there is no leak
Aircon not satisfied
