Results 11 to 18 of 18
August 20th, 2009 03:11 PM #11
may problem din ang aircon ng adventure namin. Kapag nag start wala halos lamig na lumalabas. Kapag itapat mo kamay mo sa vent parang fan lang ang umaandar. Ganun siya kahit tumagal pa ang andar basta mabagal lang ang takbo. Pero kapag mabilis ang takbo, aba malamig na!
GLX lang na diesel ang amin 2000 model. Ibig ba sabihin nito kailangan ko lagyan ng isang auxillary fan ang radiator? I don't think refrigerant ang problem kasi kakapa-recharge ko lang late last year.
Please help, many thanks!
August 21st, 2009 07:41 AM #12
Bring this to your trusted aircon mechanic, I think your compressor is not engaging properly, like what you said if it runs on low speed there's no cold air coming out only if the car is running at high speeds. Another problem would be the auxiliary fan, it may not be functioning when it needs to that's why there's no sufficient cold air coming out.
- Aug 2009
- 31
August 27th, 2009 12:44 AM #13
- May 2005
- 234
November 23rd, 2009 06:28 PM #14hello mga sir i noticed some liquid dripping from a hose leading to my front evaporator its kind of like oil is this freon?should i get my a/c checked?
November 26th, 2009 07:53 PM #15
November 26th, 2009 08:35 PM #16
sir akin, kakagawa lang ng aircon ng adventure ko 98 model din yun. super lamig na ngayon sir. try mo yung pinagpagawaan ko. sa kamias, bong baron car aircon and muffler. mura lang singil magaling yung mekaniko.
hindi ako usually dun nagpapagawa kaso yung mekaniko nag-aalaga sa AC ko nagpunta ng dubai kaya nag-scout ako ng iba. fortunately, mukhang mas magaling pa itong sa kamias.
- Jul 2010
- 7
October 8th, 2010 06:10 PM #17..g'day sirs..
..magkano evaporator core ng adventure 2002..yung maganda at mura lang that will last years?san makakahanap? (mga 3k meron ba?)
..kindly recommend good places magpagawa sa makati area..tnx guys..
October 9th, 2010 09:39 PM #18
high idle RPM at engine start
