bago po ako dito, I have a really old nissan sentra. The problem is, may leak ng tubig from the aircon na tumutulo sa carpet. lagi basa carpet ko, kakapalinis ko pa lang nga aircon. what could be the problem
usually if A/C is leaking water inside the vehicle its just the drain hose getting clogged. But you said you just had the A/C cleaned so you need to check the evaporator housing if there is a crack, or double check the drain hose cause it may have not been installed properly.
That also happens to me a lot of times with my old car. Sometimes when I remove the carpet it's wet and after about 2 days it's fine again without doing anything with it. I tried to have it checked before and the mechanic just cleaned something. But try to have it checked in a reputable aircon repair shop to be sure.
it happended to us once after nmin mg palinis, bumaha sa loob ng auto. wen i checked it, di inayos ng gumawa yung pg balik nya ng mga parts. yung drain hose nya di nakalabas yung tip kya sa loob tumulo....
