Results 1 to 4 of 4
    hi there tsikot people
    i was just wondering if u have the same problem with toyota corolla gli model 1993-1997
    the aircon fan only runs on when the radiator fan turns on so sabay sila
    i noticed that newer models when u turn on the aircon the aircon fan will be switched on.
    is there any shop that i can modify the fans to be steady and running all the time wat are the pros and con of this?
    masisira agad ang fan if you keep them running all the time. the aircon fan turns on or off in relation to the aircon compressor which in turn is based on your thermostat settings. Your engine fan naman turn on or off when your engine (water) thermostat reaches a certain preset level. pede i-wire yan to keep it on, but think about it, if you have a weak battery and you switch ignition on before you start the engine, both of the fans will work therefore robbing you of more starting current.
    Originally posted by topgun
    is there any shop that i can modify the fans to be steady ?
    i dont know with the toyotas pero sa lancer 95, kailangan mo lang maglagay ng fuse don sa isang slot na malapit sa fuse ng A/C.
    might be the same with toyotas.
    Aug 2007
    mga tsikoteers,
    i have a problem,pls give me a gud advice.ung compressor ko ay may leak,sv ng mekaniko ay shaft seal dw,ano kaya ang maganda bumili ako ng bagong compressor o papalitan ko na lang ang shaft seal?Toyota corolla xe 94.my alam po ba kayo na mgaling gumawa,taga cavite po ako mga tsikoteers.
aircon fan problem
