Results 1 to 9 of 9
    May 2005
    Nakakasira ba nang compressor yung patay-bukas ang aircon mo. May nagsabi kasi sa akin na yung mga aircon sa bahay, pag pinatay mo sya, antay ka muna nang 5 mins bago mo buksan. Ganito rin ba ang case sa Car Aircon?
    hindi.
    kahit palaging naka bukas ang aircon mo, patay-sindi rin naman ang compressor dahil kapag na-achieve na yung temp, namamatay ang compressor. tapos sindi ulit kapag nawala ulit sa temp.
    Signature
    why, on-off ba lagi car aircon compressor mo? as in short-cycling (few seconds off then few seconds on). baka sira ang thermostat?
    or maybe (if the on-off interval is longer) mataas masyado ang setting tapos wala ka tint kaya madali uminit sa car, so on-off ang compressor? try mo lower temperature setting, maybe this will help. this will make the compressor run longer, then it will also take a longer time for the air in the car to warm up.
    A/C compressors are quite robust. Basta huwag rapid cycling, they can withstand on-off-on cycles (e.g. pinapatay mo dahil giniginaw ka). Baka mas mauna mo pang masira yung switch mismo.
    otep,
    tama ka dyan basta d lemon yung compressor, masmatagal pa buhay nyan sa switch mo. hehehe.
    May 2005
    Wala naman problem AC ko. Pero kasi minsan kelangan kong gawin yun. Example, nagpa gas ako. Pinapatay ko yung makina ko so syempre, kasama din dun yung AC. Tapos pag aandar na ako, Im kinda anxious na buksan kaagad kasi nde pa nya naabot yung tamang time bago buksan ulit. Pero I agree with all your thoughts. Thanks. Galing nyo talaga!
    Jul 2005
    Quote Originally Posted by goldencoil
    What do you mean?Are you playing with your aircon switch on and off or the aircon itself automatically goes on and off by itself??????
    mga tol ask ko lng kung anu magandang gawin sa compressor ko.kasi pag start ko nang makina buhay agad compresoor ko.khit hindi ko pa on ang aircon cympre hndi pa lumalamig kelangan muna i on yung switch.pro bkit kya on agad yung compressor?thanks
    kasi last night when i turned off the engine nalimutan ko i off yung aircon nung i on ko yung engine yun cympre on na agad yung aircon then the following day basta istart ko cya ganun na naka on na agad compressor
Aircon Compressor Maintenance Question
