Results 11 to 18 of 18
October 28th, 2002 08:27 PM #13Originally Posted by Dieseler
amacatan,
Don't worry about springing a leak. Dalawa lang naman ang connection ng a/c evaporator sa a/c system plumbing. Both are hard lines with rubber gaskets.
- Jan 1970
- 14
June 18th, 2003 05:43 PM #15
jayeina,
Check mo muna kung bakit nabawasan. Mahirap yung dagdag ng dagdag tapos napupunta lang sa hangin.
Check if your vehicle uses R12 or R134a
June 19th, 2003 10:21 AM #17Originally Posted by OTEP
Yung corolla ko dati nasingitan ko ng s/s screen before the blower which somehow trapped dust before going to the evaporator. Cleaned the screen monthly kahit hirap tanggalin. This way, di ako nag-release ng freon. Di ko pa na-try sa XTO ko.
Yung condenser naman, weekly pressure washing lang.
Dudumi at dudumi kasi talaga ang evaporator dahil sa dust sa air kahit saradong sarado ang vehicle mo. Lalo na kung di regular ang linis ng car mats. Dust also enters doon sa vent kasama ng fresh air kung nagoopen ka ng vent. Ang masaklap nito e kung may kasamang small pcs of leaves.
Is cleaning the aircon necessary? I believe the answer to that is YES. The frequency all depends on how keen the owner/user is in minimizing the dirt accumulation sa evaporator & condenser. Correct me if I'm wrong pero I believe dirt will also be the cause of the leak sa evaporator coils when it eventually reacts chemically with the metal. Pag ito ang nangyari, di lang linis ang gagawin sa ac mo, palit ka pa ng evaporator coil.
Di po ako expert pero sana makatulong. Thanks.
June 19th, 2003 10:49 AM #18Originally Posted by TEAL
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
