Results 1 to 7 of 7
    The air valve on my portable compressors leaks a bit of air while I am pumping in air to the tires.
    Is this repairable?
    A new electirc air compressor costs around P600.
    Thanks!
    Dec 2003
    afaik wala ata replacement for taiwan mini air compressors..buy a new one nalang
    Feb 2005
    ano brand yan??
    WBR,
    u might want to try this , buy a replacement chuck and an air valve na pang malaking compressor, a tube clamp. saka palitan mo un damaged air valve. usually un rubber insert sa loob nung valve ang napupod di ba ?
    Quote Originally Posted by red888
    yup... ung ang napudpod.
    ano yung replacement chuck? paano pala un? puputulin ko yung air hose?
    di ba may nakapalupot na " black wire " dun sa base nung valve ? alisin mo un at hatakin un defective na valve , then press in un replacement valve , un air chuck eto yun kamukha nung mga air valve sa mga gas stn. remember ? dalhin mo yun defective valve sa hardware store mo. para may sample at comparison. ang importante dito e un duktungan o un connector end nung chuck , kung pareho ng laki nung sa defective valve na papalitan mo .
    The rubber inside the chuck can sometimes be replaced at hobby shops (e.g. those sporting goods store at the mall). May mga ganyang gasket din kasi ang mga Airgun/Daisy.
    Otherwise, replace it with something beefier na lang.
Air Valve for Compressors - Repairable?
