Results 1 to 10 of 10
    Jun 2008
    Patulong naman po. My Accord 1996 always overheats whenever I turn off its AC. Newly overhauled ang radiator at walang water leaks whatsoever. Pag naka on ang aircon, wala naman pong problema at hindi nag-ooverheat kahit sobra ang traffic. Ano Po kaya ang dapat ko pagawa?
    Quote Originally Posted by Vcong View Post
    sosyal ng car ha...gusto niya naka-aircon siya...hahaha...anyway, baka yung fan mo may problema...kapag pinapatay mo yung aircon, sumasabay siya which should not be... or baka mahina na yung fan na naiiwang dapat bumubukas kapag off ang aircon...or lastly, baka yung thermostat?
    possible cause is the cooling fan circuit . check the fan if it turns on when the temp gauge reaches just above the half way mark .
    Nov 2003
    the thermoswitch is busted. pag sira yun the rad fan won't turn on by itself. pero pag naka a/c ka sumasabay talaga sya with the a/c fan.
    replace it and ok na dapat. sana no major damage to the engine.
    Jun 2008
    Had the thermoswitch checked and it was busted. Had it replaced and everything is ok now. Thanks for the advise speedyfix!
    Nov 2003
    no problem!
Accord Overheating Problem
