Hi. I drive a 96 Corolla. I just had my AC repaired today. Exactly a year ago I was in the same ac repair shop. Below are the details of what was done to my car:
Sep 2006:
General Cleaning - P850
Flush System - P300
Replace Filter Drier Denso Original - P1500
Replace Cooling Coil Serpentine -P4000
18 Oct 2007:
General Cleaning - P1,100
Flush System - P300
Replace Filter Drier Denso Original - P1,500
Replace Expansion Valve Denso Original - P1,600
I am really frustrated because after all that has been done, my AC doesn't function as well as it did before. It got even worse because before the repair/replacements done today I could do with just number 1, but now I have to switch to number 2 even if I have no passengers at all. I was told that the reason why the drier broke down so easily was because my radiator was leaking (which is true coz I saw it myself). Given that it is true, I just don't understand why it's still mainit. It really isn't just my imagination coz before the recent break down I really don't go above number 1 when I'm driving alone e going home from the repair shop I was a second away from brreaking a sweat. It wasn't that hot naman. Also I noticed that the pitch of my car horn got higher. It sounds so bad. I thought I was just imagining it but our helper didn't even recognize the horn and my dog didn't even bark thinking that it was another car. I feel dyaje to go back to the repair shop just a day after coz they might say that there's nothing wrong naman. Also the mechanic might think that I'm too finicky. Also do you guys know what the temperature inside the car should be when the AC is on low? They didn't show me the temp kasi. Last year they showed it to me before I left. So do you guys recommend that I go back tomorrow or should I just switch to another repair shop? or should my priority be buying a new radiator? The top portion is leaking badly kasi, they said that if I don't have it repaired immediately, it might cause the other parts near the radiator to break down as well (from the heat) . Thanks![]()
