Results 1 to 10 of 20
September 13th, 2005 10:28 AM #1
I would just like to confirm kung compression bearing nga prob nito before i go to mang mario.
Before kasi umiingay under the hood when i turn on the A/C right away after engine starts. Sounds like "kwik-kwik-kwik" pag magaaccelerate. Kala ko compressor or fan belt. Pero nacheck ko, mukang ok at tight naman.
But right now, kahit off yung aircon and hindi properly warmed-up yung engine maingay talaga siya when you step on the gas. so kailangan warm-up yung engine nang matagal bago paandarin para di umingay.
Please advise kung talagang compressor bearing to or other mechanical probs bago ko dalhin ke mang mar.
Thanks.
- Sep 2005
- 103
September 13th, 2005 11:08 AM #2Graphire,
ganito muna gawin mo para malaman mo kung belt ung diprensya, pwede kasing mahigpit sya pero damage na ung mga ngipin nya.
try mo patakan ng tubig ung belt na pinagdududahan mo na maingay, kapag nawala ung ingay nya, malamang worn out na ung belt mo or masyado mahigpit. have it replaced na lang.
Hope it helps!
Betz
September 13th, 2005 05:34 PM #3
thanks betz. pero bago pa yung alternator and compressor belts nito e. punta na lang cguro ko ke mang mario to have it checked. how much kaya abutin damage nito kung cleaning, oil and palit bearing ke mang mario?
September 13th, 2005 06:06 PM #4
Try mo luwagan ng todo ang a/c belt mo. Kapag nawala ang sound, suspect the comporessor bearing.
- Oct 2004
- 89
September 13th, 2005 06:30 PM #5that kind of noise happened to my car na before...it turned out to be the bearing on the pulley that tightens the aircon belt...di ko pinansin since nawawala pag mainit na yung car kakatakbo...soon enough, the bearing gave way and na stuck up siya...nagstall yung car kasi ayaw umikot ng makina...mura lang to replace the bearing on the pulley...
September 13th, 2005 06:33 PM #6
jayelgee,
Your story reminds me of our Community Medicine Canter. Nag-seize yung a/c compressor pulley. Hehehe. Pati engine hindi mag-start.
- Jun 2005
- 3,774
September 13th, 2005 09:39 PM #7hmmm.... pwede pala ganun? pag hindi umandar ang compressor magstall ang engine? malas naman nun... i'll keep a swiss army knife na lang para if ever mag-stuckup ang bearing, putulin ko na lang agad ang belt para di tumirik
- Oct 2004
- 89
- Oct 2004
- 89
September 13th, 2005 10:25 PM #9Originally Posted by sirkosero
- Sep 2005
- 103
September 14th, 2005 10:50 AM #10Madali lang magpalit ng bearing ng pulley, nangyari na rin yan sa akin b4, were on our way to batangas, nasa C5 pa lang kame nang biglang umusok ung engine compartment, tigil ako agad. pop the hood open to see what happened. nakita ko umuusok pa ung bearing ng pulley ng aircon, niluwagan ko sya para maalis ko ung belt. then tuloy ang byahe, until we reached turbina, nakakita ako ng auto supply. tiyempo meron silang bearing for the pulley. bili ako agad tapos ako na rin nagbaklas kabit nung pamalit. medyo umuulan kase hirap walang aircon. hehehe just a matter of 15 mins or less were back on the road agen.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
