Results 1 to 20 of 22
    May 2012
    mga sirs i need some help. yung hyundai h100 kulang yung lamig sa harapan compared sa likuran. yung van namin is 17 years old na and since year 2007 nag loko yung aircon nito. pinalitan na namin ang maliit na condenser nya (yung nasa ilalim ng front passenger area), pinalitan din namin yung expansion valves, drier, compressor (original) at tinanggal ng service center yung solenoid valve kasi na sira na raw. ano po ang inyong masusuggest nito mga sirs? also, malamig siya kung madaling araw, umuulan, sa gabi at kung nag lolong distance trip kmi but mainit kung nka standby na sa city o traffic at during midday.. Thanks in advance..
    Jan 2012
    2007 pa huling ginawa sulit ka na diyan 5years, nag babawas na yan ng refrigerant pa hanap mo ang leak, sabay general cleaning na,
    Ilang psi ang low side at high side? Baka undercharge pa. Pero malamang compressor na yan. yung compression niya kinakapos na. Meron kami madalas nagagawa sa pregio na ganyang problema.
    Jan 2008
    most A/C shops refer only to the pressure charge... this is correct, however, you should also consider the weight of the refrigerant charged to the system.. the pressure may be correct but the refrigerant is under weight
    You are correct, also consider the weight of the refrigerant in charging the system. If the parts are all OEM, you can use the total weight of the refrigerant charged which is provided by manufacturer otherwise use the sight glass and by subcooling method.
    Aug 2008
    Alin po ang tama? Yung "pressure" 'o yung "weight".
    May 2012
    Wlang leaks yung system.. Sobrang lamig bsta sa malalamig na panahon, but during tanghalian, sobrong init naman.. Sabi ng repair shop dito sa amin, ok naman dw yung pressure charge..
    Jan 2012
    Quote Originally Posted by Alfrance05 View Post
    Tinanong mo sana yun technician kung bakit ganon talo ang lamig pag tanghalian, pag di ka satisfy sa sagot mag second opinion ka naman sa iba..
    marami kasing parts ang auto aircon. puwedeng sira ang aux-fan ng condenser, or marumi lang ang cooling coil, puwedeng compressor, filter drier, expansion valve at iba, dapat my gawin kayong remedy para makita kung my pagbabago, depende na yan sa gagawa....
    Feb 2012
    ganun din sa liteace ko malamig pag makulimlim pero pag maaraw mainit
    Jun 2011
    Quote Originally Posted by sotel View Post
    sir ang problema ng A.C. NYO EH CONDENSER malamang nag hi pressure kaya nawawala ang lamig pag na traffic. Common problems yan sa mga more than 4-5 years na vehicles. hindi na nakaka daloy ng mabuti ang freon sa condenser to dispense heat.... the best is to have it clean sa MARUNONG TALAGANG NAG LILINIS ng condenser... internal ang cleaning ang sinasabi ko po.... pag hindi nakuha ng gumagawa sa cleaning ibig sabihin hindi nya alam linisin ng tama
    ang problema lang pag flush nila ang condenser possible na may matira na chemical or water sa loob ng condenser that will cause to block your condenser, expansion valve(natirang moisture will freeze) or drier naman dapat kasi totally walang moisture ang loob ng system ng a.c natin, pag hangin ang gagamitin may moisture po yun.. (yung pinapagawaan ko sir nakita ko meron silang malaking oven para pangpatuyo nang mabuti sa loob ng condenser)..... . palitan nyo na po nalang ng bagong CONDENSER yung pinaka main.... kaso nga lang sir baka pati na din yung bagong palit na condenser nyo na maliit eh na apektohan na at madumi na din.... its better to flush it....
    another problem yung system nyo baka dating R12 converted to 134a, most probably hindi po nila na flush ng mabuti ang system meron pang natitirang R12 sa loob... kung hindi kasi tamang chemical ang ginagamit nila sa pag flush ng system siguradong meron matitira dun na residue.... it will cause the highpressure at nahaluan po ng kunting R12 ang 134A.... nagbabago na po ang refrigirant natin kahit kunting refrigirant lang ang nahalo... it will cause agad ng high pressure
    Feb 2012
    sir indi kaya dahil sa isang auxfan lang ang gumagana ?dalawa kc un sira ung isa
    Jun 2011
    dalhin nyo po dun sa pagawaan ko Q.C. AREA nga lang... sure ako super lamig yan.... money back guaranty pa
    May 2012
    No problems talaga sa mga system components yung aircon ko, but sa lamig meron. R134a po yung system from the start.. Kung condenser po yung problem, ano po ang inyong ma suggest na type ng condenser? I have tried several repair shop including mga casas, yun parin ang problem.. Do high pressure affect my compressor?
    Jun 2011
    yes sir.. pag mataas ang pressure mas hirap bumonba ang compressor nyo... pag dating sa condenser sir hindi ko masyado alam ang bagay na yan... dun nyo nalang po ipagawa sa pinapagawaan ko at sa tingin ko mas magaling sila sa casa at ang casa pagdating sa car sila ang magagaling... pero pag dating sa A.C. ang magagaling dyan eh yung mga aircon techician na nag aral po talaga at puro a.c. ang ginagawa.... try nyo dun at money back naman dun.... hindi ako naniniwala na hindi nila kayang palamigin van nyo.... possible din pala na maliit ang subcondenser nyo po.... sabihin nyo lang ang problema nyo at ask nyo kung ano ang solution, then ask nyo din kung ano pa ba ang dapat gawin para mas malamig.....
    may van po ako mb140, 3 ang evaportor 2 condenser... hindi nag hi-pressure.... pag kakatanda ko nasa 32-33 low side pag naka idling, at 215-220 hi side...---- pag rev. ko ang low side nasa 25, ang highside 190-200 ata po not sure....
    May 2012
    Btw sir, meron effect ba sa lamig kung tinanggal ang solenoid valve? Thanks..
Hyundai h100 aircon problem
