Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 141 to 160 of 193
    #141
    Toyota delivered my car after almost 3 weeks. The AC is working but it is still not as I expected! I knew it the moment I opened the AC. 30C yung reading ng outside temp. When I turned on the AC at 24C isang blower lang. And this was from a day sitting at the garage. Normally the blower should be at full blast then gradually lower as it reaches the desired temp. I do not think it should just be 1 blower considering that the weather is not cold tonight.
    I don't want to complain anymore. I'm trying to be optimistic at least kotse lang problema ko and I still have a roof over my head, eat regular meals and my family is in good health. But I cannot help but cry from helplessness. Nakakasama talaga ng loob. Cooperative naman ako sa casa. They even charged me P500 dahil naubos na gas from the AC testing and road test. I would assume Toyota Pasig really made an effort to fix my car but I think we are not on the same page. I tried the AC ng hindi auto climate, malamig naman. So I think something is really wrong with the sensor. I asked them to check this pero parang hindi naman. They practically replaced the whole AC system, but did they check the sensor? It's like they burned the house down to kill a rat
    Can someone please tell me what specific instructions I need to give the casa for them to check this? Yung ibang Altis owners nagrereklamo sa lamig e yung Altis ko kulang sa lamig. And I do know that the Altis AC is super cold. Mine was before I had problems with the AC. Iiyak na lang ako sa sama ng loob at kung bakit minalas ako sa Altis ko.
    #142
    Maam Cathy... Can you pm me problema Ng altis mo po.. Timatamad po Kasi ako mag hanap.. Then I can forward your message kay Celine...
    thanks glenn, suko na ko, ayoko na sa Pasig. Mabait mga tao nila pero ultimately hindi naman nila masolve yung problema ko. Lipat na lang ako ng Bicutan or BGC.
    Jun 2011
    #143
    if everything else fails, bring it to other aircon shop outside casa... Ang casa naman kasi hindi naman aircon ang field of expertise nila... pa check mo Sa EDS car aircon. It happened to me ma din kasi sa Mb ko kung Saan saan Ko na dinalang shop.. Pinalitan Na 2x ang compressor, expansion valve etc. pero ganun pa din... Dinala ko sa eds car aircon, after a series of test... Naayos nila a.c. Ko...
    Jun 2012
    #144
    Personally mas may tiwala pa ko sa shop na specialize sa aircon kaysa sa casa na minsan mga ojt lang nagttrabaho sa sasakyan mo. Give it a try sa labas
    #145
    maybe look ka na lang sa mga shops outside na may scanner and much better yung may oscilloscope. read all sensor data and parameters (pid.) one example is the ambient temp sensor (kung ang reading ng sensor ay mababa ang ambient temp natural hindi nya masyadong palalamigin ang ac or may chance pa na hindi nya paganahin ang compressor). in car temp sensor ganun din, yang mga solar sensors din. the casa should monitor manually kung ano ang mga inputs and outputs ng ac amplifier. sometimes may problema din either electric or mechanical and mga blend doors.
    Dec 2007
    #146
    Cathy, will just try to address yung sinasabi mong blower strength. Sa experience ko, full blast lang sya pagmainit yung loob ng car, as in nabilad sa araw. Kung hindi naman bilad, kahit naka auto ac ay hindi nagfull blast ang blower ko.
    #147
    Minsan may mga lokong SA rin... pag medyo may kakulitan ka pwede ka bigyan ng sakit ng ulo sa dulo. Sa huli huling tawa pa rin sila. Di rin ako masyado mahirit sa freebies pero i compare sa ibang dealer tsaka ko itatapat sa kanya - walang pilitan. Tapatan nya or not fine.
    Parang dealing with waiter, pakisamahan mo sigurado asikaso ka. Nasa iyo naman kung paaabuso ka.
    #148
    Quote Originally Posted by timo07 View Post
    Yup pero yuns sakin 1 bar lang. And that was from sitting at the garage the whole day.
    Pag hindi ka auto climate, ilang bar AC setting mo with this weather?
    I dunno what the **** kind of testing Toyota did. Bakit 3rd compressor na. MAYBE JUST MAYBE THE FCKING COMPRESSOR IS NOT THE PROBLEM. Ilang araw na ko umiiyak sa inis
    I had good relationship with my SA for 5 yrs before this happened. I actually held back complaining to TMPI because of that.
    #149
    Does anyone know how I can contact Toyota Asia Pacific or Japan?
    #150
    So sad your SA can't do something to have it fixed.
    #151
    So sad your SA can't do something to fix it.
    He is good in taking care of his clients pero I guess there is a problem with their technicians. Since special case na yun sakin, dapat tinutukan na. They give me that impression na tutok sila but the results are not consistent. Yung faint noise which I really think comes from the blower was not replaced. If they did a thorough check at ganyan pa rin then this casa must be full of nincompoops
    Dec 2007
    #152
    Kapag mainit, nag auto ako or around 3 bar sa manual para lumamig kaagad. After a few minutes (around 30 during midday) after iadjust ko na sa 2 or even 1 bar. Sa totoo lang nalulula ako sa full blower blast.
    Dec 2007
    #153
    So hindi pa rin ba sya lumalamig?
    #154
    _Cathy_ I didn't read through all the pages but I think It's time to change casa; preferrably Toyota owned so escalation is quicker. I'll simulate your conditon of outside temp of 30C then set the ac to 24C on auto to note what fan speed it will select then do some screenshots of sensor readings if any on techstream once I get the chance.
    Quote Originally Posted by shok View Post
    I already suggested that in the thread. Hopefully you do some technical testing to satisfy our cravings for results in this thread. Hehehe. Wish I could bring my fluke k-type thermometer but im not in the country. It only takes a few minutes to do these tests.
    Also high and low pressure test but i think thats already too much. Re-vac sana sa labas.
    Apr 2009
    #156
    Yours is a horror story for one who believed so much in a good brand of car but with a bunch of mediocre SA & technicians. Suggestion is you just have to have it diagnosed in an outside reputable & competent aircon shop for 2nd opinion then have it repaired in another Toyota casa with a reliable service technicians. I hope our fellow tsikoteers will recommend the best toyota casa in your area. Im frm the north so i cant recommend you one. Cheers!
    May 2010
    #157
    Saan ung eds?
    Jun 2011
    #158
    Meron sa waze search mo nalang eds car aircon... Quezon City..
    #159
    This is what I see during diagnostics for the AC in GTS.
    Setting is 28C with +2C offset (30C actual setting) but room temp sensor is at 24.75C already.
    Our MID is showing the adjusted ambient temp w/c is showing 31C on the screen and 30.64 in GTS.
    I wonder what your readings look like at the same temp setting for them to say that it's Okay?
    #160
    Toyota said they will send me a copy of their report. It's very frustrating
11th Gen Toyota Altis Aircon Problem
