Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Mar 2018
    Guys,
    Any suggestions on how to easily defog your glass panels? Do you apply a solution (glass treatment) on them?
    TIA.
    Jan 2008
    Guys,
    TIA.
    Nasaan ba yung fog? Sa loob o sa labas?
    Kung sa loob.. turn ON the airconditioner
    Kung sa labas.. turn OFF the airconditioner
    Mar 2018
    Sa labas good buddy.
    Sa previous car ko hindi naman nagfog ang glass panels ngayon lang sa new car.
    Lalo na kapag maulan. At first ok lang then biglang mag fog ang mga glass panels.
    Jan 2009
    It happens when the outside air is very humid and the windows are cold due to the A/C.
    First thing to do is to adjust the A/C vents to minimize airflow hitting the windows. 2nd, you can set the A/C to a touch warmer setting. Adding half-a-degree or so would usually make a difference.
    Sep 2017
    Just pop up the windows to equalize the temp. Normally within 30 secs you will see the fog go. away
    Sent from my ASUS_X00QD using Tapatalk
    Mar 2018
    Thanks for your shares good buddies
    Dec 2009
    Quote Originally Posted by E*tpc View Post
    When its raining hard, opening the window is a bad idea
    Just open the vent (stop recirculating air) to let cooler air from outside on to wipe that mist out while keeping both hands in the steering wheel
    Doing so will make the cabin cooler than outside
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Dec 2009
    Kung nasa labas ang mist, wiper can handle it
    Kung hindi matangal ng wiper nasa loob ang mist. Open your aircon vent
    Mar 2018
    Thanks man
    Mar 2018
    By the way, I just read this sa manual hehe.
    Dehumidifying
    Set the air flow selector to a desired air
    flow selector position, the temperature
    selector to the desired temperature position
    (other than “OFF”) and the blower
    speed selector to the desired blower speed
    position. Also select “FRESH AIR”.
    NOTE:
    Because the air conditioning system dehumidifies
    the air, turning it on will help keep
    the windows clear
Effective Defogger
