Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    mga sir, may tanong lang po ako.. nabasa ko kase sa manual ko na kailangan daw na gamitin ko or bilhin ko eh yung "commercially-available windscreen washer fluid"... meron po bang ganon?.. sabe kase sa manual na bawal daw gumamit ng water solution, it can damage the windscreen washer pump...
    any suggestions or reaction po tungkol dito....
    Apr 2005
    try wurth.
    although plain water will do.
    I found a concentrated windshield washer fluid that I have used half only, some 4 years ago. Does this stuff expire?
    I have not seen any expiration date written on its container......
    7101:hooray:
    Sep 2005
    may nabibili sa mga hardware.. yung kulay blue na ni di dillute sa 4 liters water..
    I rarely use my windshield washer but I use pre diluted hair shampoo, mga 1 tsp sa 1 liter para madulas and smooth lalo sa rear shield sabay sa ulan.
    matagal ko na ginagawa yun tumagal ng lagpas 20 years mga tsikot namin dati mga buo lahat ng wiper washer.
    pwede po bang malaman yung pangalan kung sakaling bibili po ako sa hardware?.. safe po ba yun?
    Oct 2008
    Quote Originally Posted by james00112233 View Post
    Bro try mo sa ace harware "Cyclo windshield washer concentrate" although my iba pang brands sa tabi nya sa shelve 169 petotwala naman po problema
    Apr 2008
    kapatid try mo din rain-x washer fluid additive.. ok din sya..
    Quote Originally Posted by mitsukorin View Post
    Quote Originally Posted by glenn_sp View Post
    thank you sa mga suggestions nyo..
    Jun 2008
    i used waxco brand... ok naman. 10ml diluted to 1.5 liters of water
    Quote Originally Posted by kideex View Post
    same here...just put some in my washer tank. 2 capfulls to 1.5L of water...
    Quote Originally Posted by jumpman138 View Post
    saan nyo po nabili yung waxco?...
    Just want to tell everyone that premixed washer fluid is now available at Japan Home 88. I forgot how big it is, looks like a gallon to me. I bought two.
    I'm using distilled water for my washer fluid... I think I got this advice from niky about plain water or other fluids gunking up the pump and hoses over time especially for those with rear washers.
    bigbigcar.com Review: Nissan Frontier Navara 4x4 LE MT
    +1. im also using waxco, so far ok naman ito lalo pag nagputik yung windshield mo from tire splashes ng sinusundan mong sasakyan. meron sa ace, true value at karamihan ng mga home depot meron din. sundan mo lang yung instruction sa pag dilute. yung 10ml per container ok naman.
    Apr 2008
    Nakita ko yan bro. Pinagiisipan ko nga bilhin.
    Ang Laki nya mura pa.
    Kamusta po ang performance nya?
    Di ba magrarainbow sa Windshield pagtagal?
    Thanks!
    Pa-add na rin Sir Otep.
    May Drain bolt pa for the container?
    Para fresh eto lang ung laman nya.
    Thanks!
    Ok naman. Cuts through grime like the OEM stuff. So far no rainbow and mukhang no bad effect sa vehicle paint.
    Walang drain so I had to finish the whole jug muna. Just don't run the washer motor for more than 20 seconds at a time otherwise baka masunog.
    Jun 2008
    i saw a gallon of windshield washer fluid color blue just for 79.80 petot if im not mistaken. no instruction but a phrase says " no mixing needed......" anyone had used this product? safe kaya ito? product name: Xtreme BLUE windshield washer.
    Aug 2006
    ako isang JOY (1pakete maliit na tig 10 pesos)lang tapos punuin ng tubig.ok na.ang ganda gamitin pag umuulan. tanggal ang sebo at mantsa at *** ng birds sa windshield..ang bula bula pa.
    Dec 2007
    Ginagamit ko ngayon yung nabili ko sa ACE hardware na german ang instructions at wording. Okay naman doesn't cause any rainbow sa windshield ko.
    Kakabili ko lang ng Micro Magic na windshield washer although I haven't tried it yet.
Windscreen washer fluid
