Results 1 to 19 of 19
    Mga higala .... mangutana lang unta ko sa mga set-up ninyo aron maka share ta ug mga views ba ug gamay na terminology ug ins and outs sa pag modify sa makina bitaw .
    Pareho sa ako set-up sa awto diri sa US , akong plano na lipay nako is 200 WHP lang pero sama ana na sohc ako makina unya NA pa gyud , unsay angay nako buhtaon ana other than force induction ?? kaya ba ang NA mo himo ug 200 WHp gikan sa 1.8 sohc engine ?? Stock tanan pa so sugod pa gyud sa uno . Salamat ug daghan pa na gahum sa kabayo !!
    Mar 2003
    para sa mga kapwa bisaya niya ata yung tanong niya eh, kaya nasa forum na ito ;)
    Dec 2003
    ssaloon ang naitindihan ko lang kung kaya ba ng NA set up yung 200Hp higitan sa 1.8 sohc other than forced induction..hindi ko lang sure yan..heheh..:D
    Aug 2004
    Yan din ang intindi ko... pero 1.8 SOHC, what engine? Saturn? That would be pretty hard... 150whp maybe with all the right mods and a good set of carbs, but 200whp would be very very expensive.
    wala ako maintindihan...
    Feb 2004
    meron akong nakita na article fastest 1.6 liter N/A na hatch na civic sa states withot nitrous. medyo ang laking gastos sa engine balanceing and internals.
    you might be better off just swapping to a bigger engine na turbocharged na rin para sulit.
    bisaya sad ko, pero lisud magtype sa bisaya
    andy
    Hehehehehe I did not know we do have non Cebuanos here . SOrry ...... just close the topic mods . I was not open minded enough to check that VISAYAS chapter is limited to only Cebuanos .. I apologize .
    Dec 2003
    Although from what I could infer the question sounds promising, hope in can be posted in English for everyone's benefit.
    Feb 2004
    bai, what car and engine are you starting out with?
    andy
    Basically my question is regrading about my 1.8 L sohc 4G92 engine . Is it possible to make 200 WHP w/o force induction ?? NA power lang ni siya on a 99 mirage coupe .
    yes, but not worth it at all. might as well trade it in for an evo, spend about the same money, and get a newer car, awd, all the suspension mods etc. that come with a stock evo
    Feb 2004
    unless you work for a engine "tricking-out" company and you are doing it for advertising and to prove a point (that your expertise can make 200rwhp out an engine that probably does 115 rwhp) then it doesn't seem worth it.
    either engine swap or as mentioned, get an older evo 4, 5 , or 6 na lang.
    andy
    SO answer is capable but not worth the try because of the time and money to be shelled out w/c is by the way , get a swap or another car right ?
    Next stage would be turbocharging it , is it worth the try ? I dont have plans of getting rid of the Mirage for the simple fact that I spent already money more than the blue book value of the car on the cosmetics department .
    The car has the SHOW but no GO ..... hehehe , I have talked to several mirage fanatics in the US and majority is getting a 4G63 swap or NOS . I might be on the " sohc pride " area of proving something so worth the try ni siya or might as well get the swap with a stock turbo ??
    Lastly .... I am not a speed freak .... just a little kick to back up what was claimed on the outside lang mga bai . So if the turbo is stock .. unless it is working then it stays stock .
    Feb 2004
    kung konting kick lang habo mo, just turbocharge it or supercharge it with low boost, mga 5 to 6 psi lang. ayos na yan.
    engine swap is also expensive, especially in the USA where labor costs are expensive.
    turbo or supercharger na lang. there is a complete turbo kit na binebenta sa mymitsuph, if you are earning in dollars, basig barato lang ang iyang baligya
    andy
    Actually nag inquire nako sa ERL motowerx bai sa QC ni siya based though ngutana lang ko sa uvban tao about the quality of their merchandise and ok man daw . Mao lang na ako target around 200 WHP , that is a little kick for ..... keeping up with the RSX and the ITR .
    Tnx for the replies and will check out mymitsuph pod .
    Aug 2004
    pahabol
    unless you do up a turbo/change engine its hard to get 200Hp from your 1.8
    for engine conversion still staying with NA you can try install a CA12. question is can it fit okay.
    http://www.ftowa.com/html/workshop/workshopart06.html
    to all bisaya/ cebuano speaking, please join our thread: new home for the bisdak!!!
    salamat puhon sa inyonhg pagtambong kanamo!!
    selling hohda s200 0 ,2004 model
Engine Set-up
