[SIZE=2]Source:www.abs-cbnnews.com[/SIZE](2nd UPDATE) Qantas plane loses cabin pressure, makes emergency stop in Manila
[SIZE=2]A Qantas Boeing 747 passenger plane made an emergency landing at the Manila international airport on Friday after a "hole in its belly" caused it to lose cabin pressure, an airport official said.[/SIZE]
[SIZE=2]Airport operations officer Ding Lima told local radio that the aircraft lost cabin pressure shortly after leaving Hong Kong bound for Melbourne.[/SIZE]
[SIZE=2]"The captain of the aircraft immediately called the control tower for an immediate landing," said Lima.[/SIZE]
[SIZE=2]"There is a big hole in the belly of the aircraft near the right wing about three meters in diameter," he said.[/SIZE]
[SIZE=2]He said the aircraft was carrying 350 passengers and 16 crew.[/SIZE]
[SIZE=2]The pilots "requested an emergency landing and it was granted," airport manager Alfonso Cusi said, adding he did not know what the exact problem was.[/SIZE]
[SIZE=2]Passengers reportedly said the plane, which was flying via Hong Kong with about 300 passengers and crew, plunged 20,000 feet (6,010 meters) after a door apparently "popped" midflight.[/SIZE]
[SIZE=2]Melbourne's Herald Sun newspaper reported on its Web site that passengers reported experiencing a "fairly explosive" depressurization in the cabin which led to oxygen masks dropping from the ceiling.[/SIZE]
[SIZE=2]One passenger reported that the pilot did "an amazing job" of controlling the aircraft.[/SIZE]
[SIZE=2]A Qantas spokeswoman refused to confirm or deny an emergency landing had taken place but said the aircraft had been diverted to Manila and was now undergoing inspection on the ground.[/SIZE]
[SIZE=2]"The aircraft is on the ground and is undergoing an inspection," she told AFP. "We are still gathering all the data," she said in Sydney.[/SIZE]
[SIZE=2]However a Qantas assistant supervisor in Manila said the plane had made an emergency landing, although the incident had not been "life threatening" and the aircraft had landed safely.[/SIZE]
[SIZE=2]"The aircraft made an emergency landing just after 11:00 am (local time)" Qantas assistant supervisor at Manila's international airport Lorena Dimaya told AFP.[/SIZE]
[SIZE=2]She said the aircraft had taken off from Hong Kong when it "encountered some technical problems and requested to be diverted to Manila where it made an emergency landing."[/SIZE]
[SIZE=2]"All (passengers and crew) have been taken off the aircraft and have been taken to hotels in Manila," she said.[/SIZE]
[SIZE=2]She said the aircraft was carrying "about 300 passengers and crew". With Agence France Presse[/SIZE]
[SIZE=2]July 25, 2008[/SIZE]
Nakakatakot yun ganyan, yun may air pocket nga lang, pag drop ng hundred feet nakakatakot na e, 20,000ft pa kaya![]()
