Results 1 to 6 of 6
    Jan 2008
    Baka may recommended kayo na shop ......poor contact nung switch at "P" (park) position......start ko lagi kotse at "N" position.....worry ko ...baka
    later on di na rin ako makapag start at "N" position........
    Yun sana malapit sa laguna area.......pero kung may mga shop na magaling
    gumawa ng ganito defect...OK na rin....................
    Thanks in advance.......
    May 2007
    [quote=chrismartin;990125]Baka may recommended kayo na shop ......poor contact nung switch at "P" (park) position......start ko lagi kotse at "N" position.....worry ko ...baka
    Thanks in advance.......[/quot
    Your switch selector is dirty. Heto ang quickfix na gagawin mo. Move your selector(cambio) start from Park, Reverse,neutral, Drive, 1st, 2nd, 3rd and so on. Do this at least three times enought to clean the swicth by friction to remove all the dirt into. Remember do not slammed your tranny, then start your car!
    Jul 2006
    Bad bushings can also cause this, which leads to misaligned parts (hence the poor contact). No amount of fix will repair this except to replace the bushings.
    Does the indicator light in your dashboard show that you are in the Park position when your tranny is in position 'P'?
    5101:pcwhack:
    Jan 2008
    5101:pcwhack:
    The indicator light shows park position when the tranny is in "P" position.
    Indicator light matches actual tranny location at all position (P,R,N,D andD1).
    Thank you.
    Chris
    Apr 2006
    They call it inhibitor switch. Yung iba hindi na narerepair pero pwede irekta na lang kaya lang medyo pangit kasi lahat ng gear pwede istart.
Help..Help..Repair ng A/T lever switch ...ayaw mag-start
