Results 1 to 7 of 7
    Jan 2010
    I have problem with my A/T. pag nag brake po ko may lumalangitngit, pero sabi saken sa transmission daw yun at hindi sa brake. Baka meron kayo kilala magaling A/T mechanic? para mapacheck ko bago ko sana mapagawa. hope u can help me
    Pa check mo rin sa ibang mekaniko bago mo pagalaw ang transmission mo kadalasan problema sa Automatic transmission ay Shift shock , Delay . Langitngit ngayon ko lang narinig Pwede pa sa mga brake parts nangagaling .
    Feb 2009
    Quote Originally Posted by bogartbigotilyo View Post
    bogartbigitilyo,
    is your car FR ( front engine rear drive), FF ( front engine rear wheel drive)? please identify your car make, model, year, etc.
    jick
    Jan 2009
    Just a shot in the dark... engine or transmission supports?
    Needs more info. In addition to the type of car in question, does the noise appear with the car standing still (A/T in drive with the brakes applied), or when applying the brakes while slowing down?
    Jan 2010
    its a front wheel drive, mitsubishi lancer mx automatic sir ang car ko. everytime i stepped on the brakes dun lang sya umiingay. Pero i checked everything with the brakes ok naman.
    Feb 2009
    how many percent life is remaining on your brake pads? the friction material should at least be as thick as the steel backing if it is bonded and at least 1/16 of an inch above the rivets if they are riveted. check for the warning tab which is supposed to be installed on the inboard pad on each side, also check the baking plate or splash plate for contact with the wheel
    jick
    Dec 2009
    sir same prob with my car 02 318msport bmw every shift ng drive nauuna caha pero nagana nmn lahat ng P R N D pero minsan when stepping on brakes me langitngit din.. pinatignan kona dati sabi nung mekaniko baka daw sa selector lng possible baun? *all help kung san meron available nung selector na part pm me the price * loc kung saan pwede mabili thanks!
a/t problem
