Results 1 to 15 of 15
    Aug 2010
    Hi mga sir..
    dumaan po kami sa NLEX kanina..1st, 2nd 3rd and 4th gears are all ok naman..
    pagdating ko ng 5th..kakagat sya ng 2-3secs..tapos bibitaw sya..may tunog na "krrrrrringg" tapos parang naka neutral na...
    Nissan Sentra Lec 94 Manual Tranny...
    anu po kaya problema?
    magkano po kaya gagastusin ko?
    saka recommended shops..
    malapit lang ako banawe..baka po may maituro kayo..
    salamat po..
    please help po..
    Aug 2010
    Hi mga sir..
    salamat po..
    please help po..
    The syncro is damaged and would need to be replaced.
    Dec 2010
    09202991024 dude try mo contact si boy opinaldo sa kabignayan. puro trans ginagawa nyan.
    Aug 2004
    +1 on GH. Sounds like a bad synchro. If you're lucky, you may be able to buy one brand-new locally, and if you're even luckier, the Sentra's 5th will be outside the case, and it can be done without pulling down the whole thing.
    If.
    Aug 2010
    maraming salamat po mga sirs...magkano po kaya yung synchronizer?
    yun lang po kaya problema? or baka may gusto pa kayong isabay na palitan ko para isang babaan nalang..
    *niky..na curious naman po ako sa sinabi nyo..panu po maayos yun ng hindi binababa..
    mukhang may sira na nga..sa 5th lang malala..nung tinry ko uli kagabi..lumusot din sa 1st gear..
    Quote Originally Posted by pat_17 View Post
    alternative option, surplus manual tranny swap.
    Have it pulled down muna, baka bearing nung gear lang. Happened to me dati bumibitaw yung 4th gear (different car), turned out it was just a stick bearing worth 300 petot... I'd rather have it rapaired than a surplus, at least it wont break down anytime soon if you have it repaired. Surplus kasi hit or miss...IMHO
    Aug 2004
    Hehe. Peculiarity of the Mazda FS-DE manual transmission. 5th gear is outside the casing so you don't have to dismantle the whole thing...
    Nov 2003
    replace the whole tranny. it'll probably be cheaper than finding the specific gear/synchro and paying a shop to reassemble it for you.
    Aug 2010
    Quote Originally Posted by speedyfix View Post
    magkano po kaya sir yung Buong Tranny? I assume Surplus po yung sinasabi nyo?
    Dec 2010
    Correct. Even after replacing the bad part and the transmission seems to be okay, it is possible that other internal parts would soon break.
    Aug 2010
    Quote Originally Posted by ericbalajadia View Post
    May Transmission Swap din po ba sa Transmission? or Engine lang po?
    Nov 2003
    hard to say... depends on the condition and the surplus shop you get it from.
    Nasira cguro ang synchro. Maaring nakalimutan mo mag check ng gear oil bago ka bumiyahe ng malayo. Nangyari samin yan dati, umugong ang 5th gear di namin pinansin, kumalas na. Kaya kahapon nung umugong ung 3rd gear ko di ko sya ginamit tapos parada ko sa gas station lagay gear oil, ayun salamat at di nasira...
    Replace ka na lang ng surplus tranny kasi baka pati ung iba may sira na di lang nagpaparamdam.
bumibitaw sa 5th gear...
