Results 1 to 7 of 7
    Well, I don't know if it's natural but when I shift from first gear to second(at 4,000 RPM nagiging halata. mga 3,000 di ganon ka noticeable). Konting nudge lng sa stick, pipitik na sa neutral ung shifter. same goes for 2nd gear to third.
    Well just making sure kung may problem gear box ko. Because higher RPMs=well, higher RPM ng gears sa gear box. Pero no problem naman sa other tsikots namin.
    Ung car na may problem: Cefiro A32 '98
    Well, ganyan ba cya dati? Did u do anything b4 it came up?
    Parang synchronizer problem, o wala cya talagang synchro. RPM matching pa, meaning u have to find out proper rpms for diff gear shifts.
    Aug 2004
    It sounds like your second and third gear synchros are going out... but only an inspection will tell you exactly what the problem is.
    Nov 2003
    normally synchros will result more in grinding of the gears than popping out.
    if you don't nudge it di naman sya kakalas from the gear you are in?
    Dec 2007
    makikiride po sana ako sa thread ni sir!
    ask ko lang mga masters nangyare kasi sakin to sa SLEX laguna to manila. two times pumitik and lumagutok yun kambyo ko yung una running at 100kph*5th gear biglang nagshift sa neutral ng di ko ginagalaw yun kambyo then yun pangalawa sa 3rd gear pumitik and lumagutok na naman yun kambyo. nakauwi naman ako pero hinawakan ko na yun kambyo hanggang sa umuwi para di na sya kumawala di naman sya dating ganto and napansin ko masyado malikot yun kambyo nya ngayon i mean nagvivibrate/shaky sya specially pag nasa 5th gear.. ano po kaya problem ng car ko? sana po eh may magreply thanks in advance po!
    btw honda city lxi 98 model nga po pala auto ko! thanks ulit
    Last edited by muskabeatz; May 8th, 2008 at 02:37 AM. Reason: added some questions
    May 2007
    POOCHIE & MUSKABEATZ
    Alam nyo ba ang isang most neglected overlooked problem sa tranny ay yong TRANSMISSION SHIFTER SEAT BUSHING. Karaniwang problema ito sa mga high mileage na sasakyan. Kapag itoy maluwang can cause the shifter pops out of gear kaya ang daming nag-papaoverhaul ng tranny dahil lang sa simpleng problema na ito. Go ahead change that SHIFTER SEAT BUSHING and the shifter end caps.
    Nov 2004
    had the same problem with my innova.
    casa repaired it for free since it was still under warranty. they said it would have cost me over 20K otherwise.
Pumipitik ung shifter?
