Results 1 to 4 of 4
    Sep 2011
    Ask ko lang po kung ano ang nagbibigay ng signal sa transmision para magshift ng gear, electrical po ba o ung speed?
    Feb 2009
    Quote Originally Posted by islajv View Post
    my sagot to your tanong:
    in the old transmissions, the throttle cable and the governor of the hydraulic shifted automatic trans
    in the new transmissions, the throttle sensor, vehicle speed sensor, coolant temperature and the mass airflow sensor or manifold absolute pressure sensor all input to the powertrain control module to command the shift solenoids.
    Jul 2003
    Hi Jick,
    sa bagong transmission ano ang role ng TR Sensor? Di mag-crank engine kapag di naka 'P' ?
    Feb 2009
    Part of the trans to enable or disable cranking is still the park/neutral switch. Parts that prevent engine cranking include the alarm and anti-theft system
    Posted through phlpost.gov.ph
