If it's a sycnhro problem, you won't be able to shift to certain gears.But if you lose power on 3rd and 4th gear, it could be the engine or a sliding clutch... or possibly your driving style too.
bro kung sliding sana parang may delay kaso hindi eh. di talaga bumabatak at all. ang lakas ng batak sa 1st at 2nd gear also sa 5th gear. kaya di talaga sa clutch. gusto ko lng malaman if may nakaranas dito ng ganon issue at kung magkano ang synchronizer.
[SIZE=3]Synchronizers[/SIZE]
Manual transmissions in modern passenger cars use synchronizers to eliminate the need for double-clutching. A synchro's purpose is to allow the collar and the gear to make frictional contact before the dog teeth make contact. This lets the collar and the gear synchronize their speeds before the teeth need to engage, like this:
The cone on the blue gear fits into the cone-shaped area in the collar, and friction between the cone and the collar synchronize the collar and the gear. The outer portion of the collar then slides so that the dog teeth can engage the gear.
Every manufacturer implements transmissions and synchros in different ways, but this is the general idea.
Sa lahat po ng may-ari ng Ford Ranger, Trekker or Everest na nakaranas na ng problema sa transmission lalo na po yong 2003 to 2006 na model, share naman po baka may permanent fix po kayo or advice kung saan maganda magparepair. Every year na lang po ako nagpapa-overhaul ng transmission ang hirap pa ng spare parts at napakamahal. I asked a quotation from Ford but an original assembly for a 4x4 manual transmission costs around Php 300,000. I resorted to Banawe kaya lang nagkakaubusan din ng supply dun ng surplus ibig sabihin sirain talaga ang transmission ng ford kasi marami ang nangangailangan. Ang una kung naging problema sa Ranger ay wala naman batak ang 5th gear at pinalitan lang ang synchronizer hangang sa lagi na lang nasisira ang transmission. Ewan ko lang po kung hindi rin sirain ang transmission ng mga bagong labas na Ranger and its variants. Personally, I have known five ranger owners who also have transmission problem. But in fairness to Ford, matibay ang makina ng Ford saka mabilis lalo na ang Trekker
