Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Mar 2005
    Nagloloko tranny ng 05 Mazda 3 2.0R ko and as per mechanic need to change the tranny.
    Ang problema wala makuha na same type ng tranny. Ang available lang ay 4 speed tranny from the 1.6 model or 5 speed tranny from I think 06 and up model.
    Ok lang daw ikabit either tranny kasi gagamitin prin daw yung orig bell casing ng tranny ko.
    Ang concern ko lang wala ba magiging problema sa gear ratio or programming logic ng shifting, etc?
    Salamat po sa makakapagbigay ng insights
    Jul 2013
    we did this before... 90's Toyota FX (MT to AT)
    90's Corolla (AT to MT) and (4MT to 5MT)
    90's Lancer (singkit) to Hyundai Stellar 6MT
    Pero when I was looking at the possibility of converting our Adventure to A/T - may mga nagsabing hindi sya as straight forward as Toyota's 2C and 2E (computer box issues)
    not sure kung paano computer box ng Mazda... pero how much is the tranny ba kasama labor?
    if wala ka naman talagang choice... my Lancer to Hyundai tranny conversion worked naman.
    Mar 2005
    Thank you sir
    Tranny - 15k
    Labor - 5k pag sa shop gagawin / 10k pag home service
    Nov 2017
    Quote Originally Posted by usong725 View Post
    If wikipedia and protegefaq site is accurate then it is likely the 4AT transmission for the 1.6 has the same ratios but a shorter final drive(they made a variation with different ratios but it is purportedly paired with the 1.5 engine or found in 2014+ vehicles). There is also the possibility that mazda PH used the same 4AT transmission(or atleast final drive ratio) for both 1.6/2.0 vehicles.
    ProtegeŠ FAQ - Transmission Info
    [FN4A-EL] 4AT Ratios
    1st gear
    2.816:1
    2nd gear
    1.497:1
    1.553:1 (*1.5 specific)
    3rd gear
    1.000:1
    4th gear
    0.725:1
    0.695:1(*1.5 specific)
    Reverse
    2.648:1
    Final drive
    3.683:1
    3.904:1
    4.147:1
    4.416:1
    4AT Final Drive Ratios for the 1.6(ZM-xE/Z6-xE)
    4.147:1
    4.416:1
    3.904:1
    4AT Final Drive Ratios for the 2.0(LF-xE)
    4.147:1
    3.683:1
    [FS5A-EL] 5AT Ratios
    1st gear 3.620:1
    2nd gear 1.925:1
    3rd gear 1.285:1
    4th gear 0.933:1
    5th gear 0.692:1
    Reverse 3.405:1
    Final Drive
    3.863:1
    3.458:1
    3.652:1 (*2.5 specific)
    5AT Final Drive Ratios for the 2.0(LF-xE)
    3.863:1
    3.458:1
    Mar 2005
    Quote Originally Posted by LOLZ View Post
    1st gear
    2.816:1
    2nd gear
    1.497:1
    3rd gear
    1.000:1
    4th gear
    0.725:1
    Reverse
    2.648:1
    Final drive
    3.683:1
    3.904:1
    4.147:1
    4.416:1
    4.147:1
    4.416:1
    3.904:1
    4.147:1
    3.683:1
    1st gear 3.620:1
    2nd gear 1.925:1
    3rd gear 1.285:1
    4th gear 0.933:1
    5th gear 0.692:1
    Reverse 3.405:1
    Final Drive
    3.863:1
    3.458:1
    3.863:1
    3.458:1
    With this info, mas ok na yung 4AT from 1.6 ang kunin. Tama ba?
    Salamat ng marami
    Jun 2011
    Hindi na po kaya mag repair kit ang lumang 4AT?
    Or siguro mas mura ang surplus kesa mag overhaul ng 4AT?
    Quote Originally Posted by bxr monkey View Post
    when i had my altis 1.6's 4AT fixed some years ago,
    it cost me 22K.
    i do not know how much a surplus trans would have cost, back then,
    but at least, i was reasonably sure what i was getting when i had mine fixed.
    it cost me 22K.
    Kumusta Naman iyong pagkagawa Ng tranny nyo? How did it hold up?
    Sent from my RMX3690 using Tsikot Forums mobile app
    Mar 2005
    it cost me 22K.
    Yes doc. Advantage nito kung mapinpoint yung talagang problema at magaling yung mekaniko na gagawa. Karamihan kasi ayaw mag overhaul, gusto yung baklas-kabit buong assembly
    Nov 2017
    Salamat ng marami
    its the safer option of the two since the vehicle was offered with that transmission unlike the 5AT. though the ratios seems to be better on the 5at though if my napkin math is correct (pretty much 1.6's AT's shorter gearing for 1-4 but with the 5th being the same or taller than the 2.0 4th gear).
Replace 4 speed tranny of 2.0 engine with 4AT of 1.6 or 5AT of 2.0
