Results 1 to 2 of 2
    mga sirs
    anu kaya problem .. mahina humatak lalo na sa uphill.
    nabaha kasi 'yung pajero namin..pero pinalitan na fluid
    TIA
    Feb 2009
    Quote Originally Posted by binder_clips View Post
    mga sirs
    TIA
    binder_clips,
    have you distinguished if it is engine lacking torque or transmission is not downshifting? try shifting manually to 2 going uphill and gun it then shift manually to D and see. is the engine blowing smoke? try taking off on L the manually shift to 2 then to D and feel for upshift. this aisan warner transmission you have is not fully electronic, it should shift as manually selected to a particular gear.
    jick
A/T Pajero 2001 mahina humatak & hirap sa uphill
