Results 1 to 3 of 3
    Apr 2010
    hi fellow drivers!., may problem ako sa clutch.., manipis na daw sya sabi nung kakilala ko na nakapagdrive minsan.., saka sa pakiramdam ko din., iba na yung feel nang tapak sa clutch., para magii-stall..,
    Where can I have it done? sa casa approximately 7k or up ang estimate nila., san pa kaya pwede magpagawa na okei ang service pero mura?..,
    Ask for a quotation from SpeedyFix in Mandaluyong, they can do the job for maybe less.
    http://www.speedyfixph.com/
    Ask for Migs, the owner...he also happens to be a member here in tsikot.
    Nov 2003
    i doubt 7k is an accurate clutch replacement estimate from casa. normally it runs much more than that. also, how will your friend know kung manipis na sya? there's no way to know for sure without removing the transmission. have it checked muna. baka it can be adjusted pa.
toyota vios clutch replacement?
